IP to X.25
I have an application where I would like to map IP addresses on Ethernet to a router connecting via x.25 to many remote sites. Is there an IOS feature where I can create a routing/lookup table that equates an IP address with an X.25 address for up to 2,000 X.25 nodes?
Hall of Fame Super Gold
Re: IP to X.25
Yes, that is a normal use for X.25 in IOS.
Re: IP to X.25
Thank you p.bevilacqua.
Is there a particular IOS command/feature you would recommend and does it require the Enterprise version of IOS?
Mike
Re: IP to X.25
For a very large number of map entries, use the following:
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t5/feature/guide/x25dns.html
Re: IP to X.25
Thank you again.
The only difference with my app is that I would use an ip address on a single host mapped x.25 devices over an x.25 cloud. More like TCP over X.25.
Can it still work?
DNS is good idea... : )
Re: IP to X.25
Sorry, I do not quite understand what is you case.
Re: IP to X.25
Sngle IP host conencted to router via Ethernet. The host sends to a variety of IP addresses on the same subnet which are forwarded to a single router (default gateway). Each IP address in the subnet maps to an x.25 remote address accessed through an x.25 cloud.
Re: IP to X.25
That is normal working and you can use the DNS feature, or configure the mapping in the router, as you prefer.
185
