ip urlfiltering and route-maps
cbuchmann
I'm having some problems with enabling a route-map and ip url filtering functionning properly. basically I have a router with 2 internet circuits: 1 T1 (Primary) and 1 DSL (Backup). My goal is to divert all internet traffic via the backup circuit to balance the load and give more bandwith to my business applications.
Once I enable the route map (to divert public internet traffic to my backup circuit) on my internal FA0/0 I can no longer filter traffic and everything is allowed! I verified connectivity to the URL server and everything seems fine... Am I missing some configuration steps on my route-map or interface to insure the traffic still gets filtered?
I'm running Cisco 2621 XM 12.4.10 Advance IP Services. My url filter profider is Websense. I'm also running DMVPN sourced from my T1 Interface.
Here is a subset of the routers running-config:
ip urlfilter allow-mode on
ip urlfilter cache 64000
ip urlfilter urlf-server-log
ip urlfilter server vendor websense 172.20.51.38
interface Serial0/0
description T1 to WorldCom
bandwidth 1544
no ip address
encapsulation frame-relay IETF
ip route-cache flow
load-interval 30
snmp ifindex persist
frame-relay lmi-type ansi
service-policy output QoS
interface Serial0/0.500 point-to-point
description Primary Internet
bandwidth 1544
ip address xx.xx.xx.xx 255.255.255.252
ip access-group firewalled in
no ip redirects
no ip proxy-arp
ip nat outside
ip inspect firewalled out
ip virtual-reassembly
no arp frame-relay
frame-relay interface-dlci 500 IETF
interface FastEthernet0/1
description DSL Internet
ip address xx.xx.xx.xx 255.255.255.248
ip access-group dsl-firewalled in
no ip redirects
no ip proxy-arp
ip mtu 1450
ip nat outside
load-interval 30
speed 100
full-duplex
no cdp enable
crypto map aj-dsl
interface FastEthernet0/0
ip address 172.21.160.129 255.255.255.128
ip nat inside
ip tcp adjust-mss 1300
ip policy route-map internet
load-interval 30
speed 100
full-duplex
no cdp enable
no mop enabled
ip access-list extended private_addresses
deny ip any 10.0.0.0 0.255.255.255
deny ip any 172.16.0.0 0.15.255.255
deny ip any 192.168.0.0 0.0.255.255
permit ip any any
route-map internet permit 10
match ip address private_addresses
set ip next-hop verify-availability xx.xx.xx.xx 10 track 2
Thanks for all your help & advice.
Carl Buchmann
8 Replies 8
Edison Ortiz
Carl,
You are using PBR with Object tracking, can I see that portion of the config ? (track 2).
For more information on Object tracking PBRs, please read http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123newft/123t/123t_4/gtpbrtrk.htm
____________
Please rate helpful posts.
Hi Edison,
Thanks for your reply, I have included a bigger portion of the running config. I hope this helps.
note: aaa.aaa.aaa = first 3 octets of primary T1 circuit and bbb.bbb.bbb = first 3 octets of DSL circuit.
Carl
ip inspect tcp max-incomplete host 25 block-time 5
ip inspect name firewalled tcp timeout 3600
ip inspect name firewalled udp timeout 15
ip inspect name firewalled icmp
ip inspect name firewalled h323 timeout 3600
ip inspect name firewalled realaudio timeout 3600
ip inspect name firewalled http java-list 51 urlfilter timeout 30
ip ips signature 2004 0 disable
ip ips signature 2005 0 disable
ip ips name IDS
ip sla monitor 1
type echo protocol ipIcmpEcho aaa.aaa.aaa.233
timeout 1000
threshold 40
frequency 3
ip sla monitor schedule 1 life forever start-time now
ip sla monitor 2
type echo protocol ipIcmpEcho bbb.bbb.bbb.209
timeout 1000
threshold 40
frequency 3
ip sla monitor schedule 2 life forever start-time now
track 1 rtr 1 reachability
track 2 rtr 2 reachability
ip nat inside
load-interval 30
speed 100
full-duplex
no cdp enable
no mop enabled
interface Serial0/0
bandwidth 1544
no ip address
ip route-cache flow
load-interval 30
description T1 Primary Internet
bandwidth 1544
ip address aaa.aaa.aaa.234 255.255.255.252
no ip redirects
no ip proxy-arp
ip nat outside
no arp frame-relay
ip address bbb.bbb.bbb.210 255.255.255.248
no ip redirects
no ip proxy-arp
ip mtu 1450
ip nat outside
load-interval 30
speed 100
full-duplex
no cdp enable
crypto map aj-dsl
ip route 0.0.0.0 0.0.0.0 aaa.aaa.aaa.233 track 1
ip route 0.0.0.0 0.0.0.0 bbb.bbb.bbb.209 200
ip route 172.21.160.0 255.255.240.0 172.21.160.130
no ip http server
no ip http secure-server
ip nat pool aj-pool aaa.aaa.aaa.160 aaa.aaa.aaa.161 prefix-length 28
ip nat inside source route-map f0/1-nat interface FastEthernet0/1 overload
ip nat inside source route-map s0/0.500-nat pool aj-pool overload
ip access-list extended inet-access
deny ip 172.21.164.224 0.0.0.31 any
permit ip 172.21.160.0 0.0.15.255 any
permit ip any any
access-list 51 permit any
access-list 199 permit ip any host 172.20.51.38
access-list 199 permit ip host 172.20.51.38 any
route-map s0/0.500-nat permit 10
match ip address inet-access
match interface Serial0/0.500
set ip next-hop verify-availability bbb.bbb.bbb.209 10 track 2
route-map f0/1-nat permit 10
match interface FastEthernet0/1
If you don't mind and to verify the problem is not relate to the object tracking config, can you please use the next-hop command within the route-map without the track option ?
If it works, then put the object tracking back and post the output from typing
show ip sla monitor configuration
and
show ip sla monitor statistics
Hi Edison,
The track option is working fine and the traffic is going the predicted path. My problem is that once I apply the route-map the traffic no longer gets filtered via Websense...
We were able to reproduce the problem on a test router. We noticed that by turning off ip cef that the traffic was getting filtered again, and we could say it's a workaround for the issue. Is there an incompatibility with cef and route-maps??
Carl
Carl
With IP CEF enabled, the packet is fast switched so it's not being inspected in completion by the route-maps.
HTH,
OK Thanks,
So what do you suggest? Can I disable ip cef for just that interface or for that route-map specifically?
IP Cef does help reduce the cpu load on my router, so I would prefer not having to disable it globally.
Carl
Carl,
You can use the interface command
no ip route-cache cef
to disable cef on the intended interface.
Please let us know how it works out.
Hi Edison,
The URL filtering does work when we turn off CEF, and it also works when we simply disable CEF on that interface only. So, yes, there is a workaround, but we really would like to run it with CEF... at this point I'm not sure if this is a bug or simply by design, as I was unable to find information on Cisco's Web site stating incompatibility between CEF, route-maps and inspect commands.
Carl
