Ip verify unicast reverse-path
Hi Expert,
I have Configuration as below,
pun-rtr-tpap0102#sh ip int brief
Interface                  IP-Address      OK? Method Status                Prot        ocol
GigabitEthernet0/0         172.21.7.137    YES NVRAM  up                    up
GigabitEthernet0/1         unassigned      YES NVRAM  administratively down down
ATM1/0                     unassigned      YES NVRAM  up                    up
ATM1/0.103                 unassigned      YES unset  up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Access2            unassigned      YES unset  down                  down
Virtual-Access3            unassigned      YES TFTP   up                    up
Virtual-Access4            192.168.2.2     YES TFTP   up                    up
Virtual-Template10         192.168.2.2     YES NVRAM  down                  down
pun-rtr-tpap0102#sh run
pun-rtr-tpap0102#sh running-config in
pun-rtr-tpap0102#sh running-config interface ATM1/0
Building configuration...
Current configuration : 97 bytes
interface ATM1/0
no ip address
no ip redirects
load-interval 30
no atm ilmi-keepalive
end
pun-rtr-tpap0102#sh running-config interface ATM1/0.103
Current configuration : 185 bytes
interface ATM1/0.103 point-to-point
pvc aap 1/103
  vbr-rt 2200 2200
  oam-pvc manage
  encapsulation aal5snap
  max-reserved-bandwidth 95
  protocol ppp Virtual-Template10
end
pun-rtr-tpap0102#
pun-rtr-tpap0102#sh running-config interface Virtual-Access4
Current configuration : 268 bytes
bandwidth 2200
ip address 192.168.2.2 255.255.255.252
ip tcp header-compression iphc-format
load-interval 30
delay 999
service-policy output voice-policy
ip rtp header-compression iphc-format
ip rtp compression-connections 100
end
pun-rtr-tpap0102#sh running-config interface Virtual-Access1
Current configuration : 48 bytes
no ip address
end
pun-rtr-tpap0102#
Pl's help me to configure ip verify unicast reverse-path under Virtual-access 4 .
239
