06-04-2014 12:50 AM - edited 03-04-2019 11:05 PM
Dear all,
Please i have been having these logging:
*Jun 4 06:52:20.366: %IP_VFR-4-FRAG_TABLE_OVERFLOW: FastEthernet0/1: the fragment table has reached its maximum threshold 32
*Jun 4 07:00:31.574: %IP_VFR-4-FRAG_TABLE_OVERFLOW: FastEthernet0/0: the fragment table has reached its maximum threshold 16
First I don't understand the different between Ip virtual-reassembly in and out.
when I configured the interfaces the default is in.
i can see it with show ip virtual-reassembly (interface).
here is my interfaces config:
interface FastEthernet0/0
description <<""Inside"">>
ip address x.x.x.x 255.255.255.0
ip pim sparse-mode
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
description <<""Internet"">>
ip address Real IP address
ip nat outside
duplex auto
speed auto
And here is my show ip virtual-reassembly for my both interfaces.
#sh ip virtual-reassembly fa 0/0
FastEthernet0/0:
Virtual Fragment Reassembly (VFR) is ENABLED [in]
Concurrent reassemblies (max-reassemblies): 16
Fragments per reassembly (max-fragments): 32
Reassembly timeout (timeout): 3 seconds
Drop fragments: OFF
Current reassembly count:0
Current fragment count:0
Total reassembly count:6364092
Total reassembly timeout count:3
sh ip virtual-reassembly fa 0/1
FastEthernet0/1:
Drop fragments: OFF
Total reassembly count:10985
Total reassembly timeout count:1533
And when the messages start to appear in the logging the Internet start to get really slow.
Please help me with this problem.
Thanks and regards,
Mohamed Selim.
06-04-2014 05:18 AM
Hi there,
Prima facie it looks like MTU problem, as there is fragmentation happening, Check for MTU along the path.
Hitesh
06-04-2014 05:42 AM
Dear Hitesh,
My MTU on both interfaces is 1500,
when I open the drop fragment on the interfaces the message is gone..
And my ISP MTU is 1700.
Thanks and regards,
Mohamed Selim.
06-04-2014 05:52 AM
Ping from a PC behind the router using option -f -l 1500 and see if makes through to find out path MTU to google or any public IP on the network. Also try extending the buffers on the interface.
ip virtual-reassembly max-fragments xxx max-reassemblies xxx
also you can check your MTU online
http://www.letmecheck.it/mtu-test.php
Hitesh
06-04-2014 06:00 AM
hi,
here is what appeared to me
Pinging 8.8.8.8 with 1500 bytes of data:
Packet needs to be fragmented but DF set.
Ping statistics for 8.8.8.8:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
And this is my new config now under the interfaces:
ip pim sparse-mode
ip nat inside
ip virtual-reassembly in drop-fragments timeout 5
duplex auto
speed auto
ip address Real IP
no ip proxy-arp
ip nat outside
duplex full
speed 100
and here is the show ip virtual
FastEthernet0/0:
Reassembly timeout (timeout): 5 seconds
Drop fragments: ON
Total reassembly count:0
Total reassembly timeout count:0
FastEthernet0/1:
Drop fragments: ON
Thanks.
06-04-2014 06:05 AM
hi,
see these discussion:
https://supportforums.cisco.com/discussion/10350421/ipvfr-3-overlapfragments
https://supportforums.cisco.com/discussion/11027121/ipvfr-4-fragtableoverflow
kazim
