IPBASE IOS limitation
mknair2000
Hi:
My 3750 switch has IPBase IOS,which only allows me to use EIGRP as a stub network but I have Call Managers connected behind the switch, which needs to be accessed from outside network.
Any alternate way to over come IOS limitation other than upgrade?
This is how the setup is:
Router>>>>3750 EIGRP>>>CallManager
Any suggestion?
Reza Sharifi
With IP base version of the IOS in addition to EIGRP static route is also supported.  So, if it is small network with very few devices, just configure static routes.
Reza
Jon Marshall
mknair2000 wrote:
Hi:
Any suggestion?
As Reza says you can use static routes or also RIP (i believe) but i'm confused about your query. Is the outside network that connects to the Call Managers coming via the router in your diagram ?
If so EIGRP stub would work fine for you. EIGRP stub simpy advertises the network(s) behind it so you would still be advertising the Call Managers to the router and from there to wherever you need. With EIGRP stub you coudl advertise a default-route via EIGRP from the router so that the Call Managers know how to send the return traffic.
Or are the Call Managers accessed via a different link from the outside network ?
Jon
Leo Laohoo
If you upgrade to 12.2(55)SE and OSPFv1 is supported on IP Base feature set.
