Silver
%IPFAST-2-PAKSTICK: Corrupted pak header for BVI1
I have recently upgraded a 1760 router with release 12.3(7)T12. Since the upgrade the router displays errors on the console.
Nov 11 12:04:02.371: %IPFAST-2-PAKSTICK: Corrupted pak header for BVI1, flags 0x8A
-Traceback= 800C5078 80B0F0AC 80B104F0 802BAF8C 802C1330 8021FC1C 802B1A3C 802B1A3C 8021FCDC 803D2B60 803D2B60 803DF474 8014474C 8013FFE8 80224728 80227F30
Nov 11 12:05:06.368: %IPFAST-2-PAKSTICK: Corrupted pak header for BVI1, flags 0x8A
-Traceback= 800C5078 80B0F0AC 80B104F0 802BAF8C 802C1330 8021FC1C 802B1A3C 802B1A3C 8021FCDC 8013FFDC 8013FFD4 80224728 80227F30
When I turn fast switching off, the messages dissapear.
Has anyone faced simular problems?
Router#sh ver
Cisco IOS Software, C1700 Software (C1700-K9O3SY7-M), Version 12.3(7)T12, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Fri 12-Aug-05 13:41 by alnguyen
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
Router uptime is 1 week, 19 hours, 37 minutes
System returned to ROM by reload
System restarted at 17:28:55 cet Fri Nov 11 2005
System image file is "flash:c1700-k9o3sy7-mz.123-7.T12.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1760 (MPC860P) processor (revision 0x500) with 59132K/6404K bytes of memory.
Processor board ID FOC073501P1 (2719306673), with hardware revision 0000
MPC860P processor: part number 5, mask 2
1 FastEthernet interface
1 ATM interface
1 Virtual Private Network (VPN) Module
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Router#
VIP Purple
Re: %IPFAST-2-PAKSTICK: Corrupted pak header for BVI1
the only software bug I could find is the following:
A Cisco router that is running fast switching (not Cisco express forwarding)
and software crypto might display the following message:
%IPFAST-2-PAKSTICK: Corrupted pak header for FastEthernet0/ 1, flags 0x80
-Traceback= 6026398C 60EA7DE4 60E83840 60E82C04 6035E464 6035E450
%IPFAST-2-PAKSTICK: Corrupted pak header for FastEthernet0/ 1, flags 0x80.
There is no workaround.
This one is actually for older (12.0) IOS versions. You might want to check if you have fast-switching (ip route-cache) configured on your router.
Also, can you post your configuration ?
GP
Silver
From my initial posting you could have read that I turned fast switching off.
The router has CEF enabled globally but the "no ip route-cache" switches both fast and cef switching off. However this solves the problem, but is merely a workaround. I will try a newer software image if available and see what happens.
554
