IPLC requirements
Can anyone help me to list all the required hardwares and softwares for an IPLC connection.
1 ACCEPTED SOLUTION
Re: IPLC requirements
An IPLC link is an point-to-point link between offices gegrophaically seperated by country borders.Here you do not have specific hardware requirements except the routers and modems.
Generally the modems are delivered by the carrier itself.The carrier will give you physical layer connectivity between both your locations.Or even it may give you frame-relay type connectivity.All you have to do is identify such carrier in your country.
I want to know:
(1)Where are the 2 locations.
(2)What is the bandwidth you are looking at.
Other economical and viable solution is :you take bandwidth from local ISP( say 2mb or so) and deploy Cisco PIX VPN on both sides.
Pls revert back if u have more questions.
Pls rate helpful posts
JD
I want to know:
JD
JD,
Thanks for the information. You are so kind. God bless u and ur family.
Following is what you need in IPLC connection:
C1841-ISR x 2
WIC-1T x 2
V35 Cable x 2
IP Base IOS x 2
Hope it will help. Please rate if it is helpful.
191
