Bronze
Ipsec match address statement
In the following config we want to
have any as source but only acc. 160 works.
crypto map tnm-vpn 2 ipsec-isakmp
set peer 1.1.1.1
set transform-set trippel-des
match address 160
access-list 160 permit ip host 192.168.254.1 host 10.224.0.1
ip access-list extended test
permit ip any 10.224.0.0 0.0.255.255
permit ip any 10.225.0.0 0.0.255.255
any ideas ?
regards
bjornarsb
Re: Ipsec match address statement
The ACL that you use in the crypto map should be an exact mirror copy between the IPSEC peers.
When you change the acl at one end, you need to ensure that the exact mirror copy is available in the other peer's crypto map.else this will not work.
Check this post for similar issue.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=Firewalling&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddbfd63
-VJ
Bronze
Thanks !
If i understand your query properly at present you are having problems in matching the interesting traffic.
do create an access-list allowing the required permit statements and bind it under the crypto map.remove the existing match statement before configuring the new one.
Instead of configuring any in the access list would suggest to mention the local lan subnet being used there in your site.
regds
122
