09-22-2006 03:46 AM - edited 03-03-2019 02:05 PM
Hi, i am trying to get an ipsec tunnel between a c1841 & c877 to work, and i managed as far as tunnel is up & i could ping other side but when users tries to rdp to terminal server they fail, also live messanger fails too, i am sure c1841 is OK as other sites are working fine, but not sure about the c877
09-22-2006 03:55 AM
sorry forgot to add that even user using cisco vpn client, whom could connect can't rdp or anything, they can't even ping beyond the router LAN ip
09-22-2006 06:14 AM
Regarding your LAN-to-LAN VPN... If you can ping but can't RDP it's because your traffic is larger than the MTU size permitted over the VPN...
On the LAn interface facing the remote clients, enter:
ip tcp adjust-mss 1300
And try again...
Aaron
Please rate helpful posts...
09-22-2006 03:00 PM
I don't think it is an MTU issue till now. One thing you I spot in the configuration is that your access-list Alex is incorrect. Your access-list should contain only traffic from your network to other networks.
Therefore, Alex ACL should look like that:
ip access-list extended Alex
remark to Alex
permit ip 192.168.85.0 0.0.0.255 192.168.100.0 0.0.0.255
remark to burg
permit ip 192.168.85.0 0.0.0.255 192.168.101.0 0.0.0.255
remark to cairo
permit ip 192.168.85.0 0.0.0.255 192.168.1.0 0.0.0.255
You should match traffic from your network to the remote site,
Please let me know if works and rate if I could help,
09-24-2006 02:47 AM
thanks, for you & aaraon for your replies, i did try the MTU setting, but it was set to auto before, i didn't see any result but i will re-check again, as for me i agress i thing i am missing something with the ACL's, but i had similar ACL on another cisco1841, & its working, so i don't know what went wrong here??
i am told that if no ACL & firewall is down so its like permit any any, is this correct?, i am trying to set the firewall & ACL on incoming & out going to make sure traffic i want is going thorugh & i will be back with the results, thanks & any other ideas are apperciated
01-06-2007 01:53 PM
I am having a very similar problem trough a VPN tunnel between an ASA5510 and a 871 router. If you did resolve this can you please post how you got this working.
Thank you,
01-08-2007 08:46 AM
His case maybe different from yours. Can you please paste your config to check?
01-08-2007 01:35 PM
