Community Member
ipv6 rip metric-offset and these two scenario
I know it is not a cisco documentation , but I just want to compare the concept
BigIron(config)# interface ethernet 3/1
BigIron(config-if-e100-3/1)# ipv6 rip metric-offset 1
BigIron(config-if-e100-3/1)# ipv6 rip metric-offset out 3
In this example, if Ethernet interface 3/1 learns about an incoming route, it will increase the incoming metric by two (the default offset of 1 and the additional offset of 1 as specified in this example). If Ethernet interface 3/1 advertises an outgoing route, it will increase the metric by 3 (default offset of zero in an outgoing update message)as specified in this example
As you can see for the incoming route, the metric is 1 (not zero), and for the outgoing route the default metric is zero (not one)
If I want to apply the same concepts (not default metric values) to a cisco documentation in the link below ?
The following example configures a metric increment of 10 for the RIP routing process named cisco on Ethernet interface 0/0:
Router(config)# interface ethernet 0/0
Router(config-if)# ipv6 rip cisco metric-offset 10
Since the default metric is 1 as cisco mentioned (Is it for both incoming and outgoing ? I am not sure) Shouldn't the offset here be 11 ???? the reason I am saying that: Since interface metric value is added before the route is inserted into the routing table, and since the default metric is 1, therefore 1+10=11.
