IPV6 RIP over FR
Hello
I tried to configure IPV6 RIP over FR, and i exeperienced wierd thing, I just enabled ipv6 rip and ipv6 without FR mapping, but it works fine OKed ping and OKed rouging table. it was FR main interface and no frame-relay interface-dlci xxx .... at all. Any explain?
thanks in advance
VIP Purple
Re: IPV6 RIP over FR
I think that neither RIPnG nor RIPv1/2 need frame-relay map statements to work; by default, all DLCIs are assigned to the physical frame relay interface, so if you have no subinterfaces, and inverse arp is enabled (which is the default), the RIP neighbors should be established automatically...
HTH,
GP
I missed to say this, "no frame-relay inverse-arp" configured, no using dynamic mapping, and for ipv4 actually i configured frame-realy map, but for ipv6 i did nothing.
thanks
101
