Rupesh,
The short answer is that it depends.
1. Encapsulates ipv6 directly over IP. Has less overhead than GRE for instance. You will not be able to run multicast and ISIS.
Manual configuration is required for each site (is point to point).
2. Supports Multicast and ISIS. Requires manual configuration for each site (is point to point)
3. Does not support multicast and ISIS. Does not require manual configuration for each site (is point to multipoint)
regards
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
