Community Member
IPX Routing
I have a 3550 switch which is connected to Novel server.
I have enabled brigding for all the L3 vlan on the switch and have connected the laptop directly to the 3550 switch
but i am not able to access the server.
Am i doing ant thing wrong ant thing extra need to be configured.
L3-48-Port(config)#bridge 1 protocol vlan-bridge
L3-48-Port(config)#int vlan 10
L3-48-Port(config-if)#bridge-group 10
L3-48-Port#show bridge group
Br Group Mac Address State Type Ports
1 0000.7481.7902 Forward DYNAMIC Vl5 Gi0/2
1 0000.7487.e7c7 Forward DYNAMIC Vl5 Gi0/2
1 0003.471b.d193 Forward DYNAMIC Vl5 Fa0/37
1 000d.614f.29cd Forward DYNAMIC Vl5 Gi0/2
1 001a.4bf2.602f Forward DYNAMIC Vl4 Gi0/2
1 0040.af82.1d76 Forward DYNAMIC Vl5 Gi0/2
1 0080.914c.3e2e Forward DYNAMIC Vl5 Gi0/2
1 0080.914d.73de Forward DYNAMIC Vl5 Gi0/2
Chao
Vishwa
Hall of Fame Super Silver
Re: IPX Routing
Hello Chao,
if the server is connected to a port associated to another Vlan
you need to add
int vlan x
bridge-group 10
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_46_se/configuration/guide/swfallbk.html#wp1020563
if all ports are in vlan 10 it should work (simple L2 LAN switching)even without configuring the inter-vlan bridge.
there is no chapter about ipx so fallback bridging is the right tool
Hope to help
Giuseppe
Community Member
Re: IPX Routing
Hi Giuseppe,
Thanks for the reply.
I should be able to access the server from all the vlan so the brigde group is applied to all the SVI interface and all are in same bride group.
As i have said i am not able to access the server when i connect the laptop to the switch in the same vlan.
Chao
Vishwa
Re: IPX Routing
Hello Chao,
on the same switch same vlan you should be able to reach the server using the IPX suite.
Hope to help
Giuseppe
107
