09-16-2013 11:33 AM - edited 03-04-2019 09:03 PM
I have two ISP provide MPLS L2 VPLS , Is ISP redundancy possible with a VPLS ?
I've already though about using IP SLA but there's issues when WAN in remote site is down I would have no way of knowing it.
can someone explain how to acheive this ?
Solved! Go to Solution.
09-16-2013 10:16 PM
I beleive so, but make sure your ISP enable split-horizon under the bridge-domain, so this will not cause a L2 loop.
09-16-2013 09:35 PM
It is possible but you need to check with your ISP, they either provide you with another circuit terminated at the same PE or another PE.
09-16-2013 10:03 PM
Hi, thank for reply
In that case , can I use IP sla at the HQ make redundant ? I've done it before in normal Mpls l2 but that's p2p link
I'm not sure if there's issues in p2mp
09-16-2013 10:16 PM
