Is it possible to do inter Vlan on cisco router 1841 with Trendnet switch
Dear All,
I  would like to as you that i do inter Vlan on Cisco Router 1841 and link trunk to Trendnet Switch (TEG-160WS).That this switch support Vlan.
interface FastEthernet0/1
description Link to Trendnet switch
no ip address
duplex auto
speed auto
interface FastEthernet0/1.10
encapsulation dot1Q 10
ip address 192.168.10.254 255.255.255.0
interface FastEthernet0/1.20
encapsulation dot1Q 52
ip address 192.168.20.254 255.255.255.0
My configuration is it correct with the other product.?
Note: if i change Trendnet switch to Cisco Switch it is working on the inter Vlan.
Best Regards,
rechard
Re: Is it possible to do inter Vlan on cisco router 1841 with Tr
The TEG-160WS supports 802.1q - so trunk to the router all is good.
Your diagram however dipicts something different, can you expand on your diagram?
HTH>
Andrew.
Are you tagging the traffic correctly on the trendnet?
155
