Community Member
Is the 2950/2960 appropriate for a high traffic production environment?
Should I go with a higher end model? If so which.
Re: Is the 2950/2960 appropriate for a high traffic production e
Depends what you call high-traffic, how many ports you need, and what other features you need.
I like the 3750s for high traffic environments due to the stacking capabilities and the single mgmt of multiple switches. Give those a check.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
Community Member
I also agree with using the 3750's. With those switches you will get layer 3 capabilities that the 2900 series switches do not have. That way you can create Switched VLAN Interfaces and have segmented networks.
110
