10-24-2009 11:02 AM - edited 03-04-2019 06:29 AM
Folks, I know 2800 routers are designed to handle less than 20Mbps WAN links.
Someone told there is a fiber module (in which I could connect fiber directly to the 2800 router module). I can't find such module so far.
Anyone can confirm whether there is such fiber module/connector for 2800?
Solved! Go to Solution.
10-24-2009 11:31 AM
Hello Marlon,
what are looking for?
a GE with fiber optic to be used as WAN port.
Or you are looking for a real WAN port that is fiber based:
the second means:
ATM or POS STM-1 155 Mbps as a minimum and it is not supported on this class of devices
see
you can have up to serial E3/T3 or ATM E3/T3 but these are based on BNC.
To be noted that WAN provider can usually deploy some external device to carry an E3 or T3 over fiber.
if you look for a GE fiber based module some etherswitch module supports it, but they are too expensive and in this case I would look for an external media converter
Hope to help
Giuseppe
10-24-2009 11:29 AM
Which exact router? There are 4 models in the 2800 series. And, everything is explained in the data sheet.
10-24-2009 11:31 AM
Hello Marlon,
the second means:
see
Hope to help
Giuseppe
10-24-2009 02:52 PM
In this case it would be a GE with fiber optic adapter to be used a WAN port.
In this case it would be a 2845. Thanks for the explanation.
10-25-2009 03:09 AM
A 2845?
No such model exists.
10-25-2009 02:50 PM
Yes there is! It's a mutant between a 3745 and a 2800. No Data Sheet included.
He he he ...
10-27-2009 06:38 AM
If you want to run fiber based WAN, i.e. OC3 etc. you should use the 3800 series like the 3825 or 3845. They can be had for a decent price for used. 2800's are branch routers and Cisco doesn't expect branches run anything over IMA bundles.
