Is there any way to some how add a SonicWall to a DMVPN?
I have an established DMVPN with 8 sites. The customer is swapping out a Cisco router at one site for a SonicWall. Is there any way to get the SonicWall to be send/receive traffic from the DMVPN mesh? I know it cannot be a part of the DMVPN config but is there a way for it to have a VPN to the hub router and then send traffic into the mesh?
1 REPLY
You should be able to do this
You should be able to do this with a standard IPSec tunnel from the SonicWALL to the DMVPN hub device. From the SonicWALL's perspective, the destination networks for the tunnel should include all of the DMVPN clients' IP space. The DMVPN hub will also need to advertise a route to the SonicWALL's source networks to the spokes.
127
