06-21-2017 11:09 PM - edited 03-05-2019 08:44 AM
I've asked a similar question before, but i still need a definitive clarity on this as I've had varied opinions
In this config, they have used "tunnel mode ipv6"
interface Tunnel34
no ip address
ipv6 address 2026::34:1/122
ipv6 enable
ipv6 ospf 6 area 34
tunnel source Serial0/0/0.34
tunnel destination 10.1.1.10
tunnel mode ipv6
Can you leave tunnel mode off altogether so the config would look like this?
interface Tunnel34
no ip address
ipv6 enable
ipv6 ospf 6 area 34
Solved! Go to Solution.
06-22-2017 06:56 AM
the tunnel will function without the tunnel mode command, but not as an IPv6 tunnel.
What are you trying to accomplish ?
06-22-2017 12:54 AM
'tunnel mode ipv6' is mandatory, without that command, the tunnel defaults to IP/GRE. Compare the output below:
With 'tunnel mode ipv6' configured:
Router#show interfaces tunnel 34
Tunnel protocol/transport IPv6
without 'tunnel mode ipv6' configured:
Tunnel protocol/transport GRE/IP
06-22-2017 01:14 AM
Hello George. would the tunnel still function WITHOUT tunnel mode statement?
You say it defaults to GRE/IP, so what difference would this make?
06-22-2017 06:56 AM
06-22-2017 07:07 AM
I'm just trying to understand Tunnel configs for when i sit TSHOOT. I understand now that the tunnel mode obviously depends on the type of tunnel you are setting up.
So it's fare to say that if you source and destination are ipv4 addresses then you don't need tunnel mode whatever ?
Thanks for your help!
06-22-2017 08:03 AM
you are right. GRE is the default, so with source and destination being ipv4 addresses and no tunnel mode configured, GRE is what the tunnel will default to.
Depending on which IOS version you are using, the tunnel mode options are quite numerous:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/interface/command/ir-cr-book/ir-t2.html#wp4269279348
06-22-2017 08:38 AM
Thanks for you help George.b
