ISDN and OSI layer
In ISDN, is switch-type (ex. basic-ni) making layer1 connection? And SPID make layer2? Dialer string for layer3? If yes, why layer3 use dialer number instead of IP Address? ISDN also use IP address to route packet, if IP is not in layer3 of ISDN, so where is IP?
Re: ISDN and OSI layer
look at this link...
it may help you...
http://www.cisco.com/univercd/cc/td/doc/cisintwk/ito_doc/isdn.htm#wp1020605
rate this post if it helps
regards
Devang
Silver
Devang proposed link is good that ISDN layer is not the same as TCP/IP layer....
Also remember: the layering is based on the OSI _reference_ model. Reference being the operative word here. If you apply the same reference model to the PC world:
Layer-1 = electronics inside the PC
Layer-2 = BIOS/Firmware
Layer-3 = Operating System.
:P
387
