ISDN at 128kbps
I would know if Cisco Router 1721 support ISDN backup at 128kbps.
I read that cisco 2600 don't support because those router don't support channel aggregation. But i don't know if my 1700 support it.
I try to insert on my router:
isdn leased-line bri 0 number 128
but with thi configuration my backup line don't work!
If I remove isdn leased-line bri 0 number 128, the line backup work fine but work at 64kbps!!
Can you help me?
Bronze
Re: ISDN at 128kbps
you could use PPP multilink, which bundles both your B-channels, effectively giving you 128kbps.
interface BRI0
ppp multilink
ppp multilink links minimum 2
This would configure PPP multilink on your physical BRI interface, with both channels coming up immediately.
Nethelper
Re: ISDN at 128kbps
does this multilink supports 800 series router?
i tried to do this configuration on 801 router but both channels didnt came up?
give me solution for 800 series routers
Re: ISDN at 128kbps
hi
can you post out the exact config which you are trying out there ??
regds
108
