ISDN Backup of 2 hope remote site?
Hi i have 3 routers r1,r2,r3 with 3 subnets.
---r1--frame relay1---router2---fr2--r3
I have eigrp betwen the routers.
Can I make ISDN BACKUP from r1 to r3 if the link framerelay1 or fr2 go down.
I have idea to do this with DDR static routes from network r1 to network r3 with cost of 200.
Did anyone have this kind of sitauation?
THANKS!
Does this scenario works?
Re: ISDN Backup of 2 hope remote site?
Hi Fisko,
This will work but you have to take care of access list which you will define for your interesting traffic to trigger the ISDN. Make sure about the traffic which should trigger isdn hen frame relay 1 or 2 goes down as when frame relay 2 goes down definetely some network on r3 will not be learned on r1 via eigrp so that time isdn should be triggered so I think instead of using access list to trigger the isdn good idea will be to use watch list to track the traffic and trigger the isdn incase if any frame relay link goes down.
And good idea will be to have the static routes with higher admin distance and last you can have a default route.
Ankur
VIP Purple
in addition to Ankur´s post, be aware of the convergence time of EIGRP, which, if left at the default, delays the removal of a route from the routing table. I would recommend to decrase the EIGRP hello and hold timers on your WAN links, using the command:
interface Serial0
ip hello-interval eigrp 1 1
ip hold-time eigrp 1 3
So, putting it all together, the sample configuration for your router R1 should look like this (the IP addresses used are arbitrary, yours are probably different):
interface Serial0
bandwidth 2048
interface Serial0
ip address 172.16.2.1 255.255.255.128
encapsulation frame-relay
no ip route-cache
no ip mroute-cache
clockrate 64000
interface BRI0
ip address 172.16.3.1 255.255.255.0
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer map ip 172.16.3.2 name R3 broadcast 5552000
dialer load-threshold 5 either
dialer-group 1
isdn switch-type basic-net3
ppp authentication chap
ppp multilink
router eigrp 100
network 172.16.0.0
auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 172.16.4.0 255.255.255.0 172.16.3.2 200
access-list 100 deny eigrp any any
access-list 100 permit ip any any
dialer-list 1 protocol ip list 100
line con 0
line aux 0
transport input all
line vty 0 4
login
end
Also, you might want to have a look at this document:
Configuring ISDN Backup for WAN Links Using Floating Static Routes
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_configuration_example09186a00800a3b77.shtml
HTH,
GP
Regarding of EIGRP propagation should I put this
On the serial frame relay connection between r2 and r3?
THANKS!
101
