Community Member
isdn backup point-to-multipoint
I'm looking for the optimal config for following situation
1 router with multiple bri interfaces -- connecting to several remote routers
1)So in order to bundle the bri interfaces, is it sufficient to place ppp multilink under bri interface configuration?
2)I've following config
username site1 password something
username site2 password something
interface BRI0/1/0
no ip address
encapsulation ppp
dialer rotary-group 1
isdn switch-type basic-net3
no cdp enable
ppp multilink
interface BRI0/1/1
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface BRI0/1/2
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface BRI0/1/3
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface BRI0/2/0
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface BRI0/2/1
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface BRI0/2/2
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface BRI0/2/3
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface Dialer1
ip address A.A.A.A
encapsulation ppp
no ip mroute-cache
delay 1000
dialer in-band
dialer idle-timeout 1800
dialer map ip X.X.X.X name site1 broadcast NUMBER
dialer map ip Y.Y.Y.Y name site2 broadcast NUMBER
dialer-group 1
no snmp trap link-status
no peer default ip address
no cdp enable
ppp authentication chap
ppp multilink
+ dialer list and acl and floating static
it added automatically the command under each bri interface:  isdn point-to-point-setup which I removed--> ok?
Is this config ok, for bundling BRI interfaces? --> ppp multilink
is it true that I can remove ppp authentication chap from the BRI interfaces and configure it only on the logical interface
3)if I do show interface dialer1, should I see the aggregate bandwidth? Now I see 56
796
