Community Member
ISDN BRI configuration on 1841
Hello, I was configuring a BRI on a 1841 & it appears that Layer 1 & 2 are up, but I still do not get any layer 3 active calls. I performed a "debug isdn q931 & one of the statements showed:
Aug 10 18:09:14.835: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x20
Bearer Capability i = 0x8890218F
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x83
Keypad Facility i = '18007931089'
*Aug 10 18:09:15.747: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xA0
Channel ID i = 0x89.
*Aug 10 18:09:16.787: ISDN BR0/1/0 Q931: RX <- PROGRESS pd = 8 callref = 0xA0
Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
Signal i = 0x01 - Ring back tone on ....
we are using 56k off of the BRI interface like the customers other sites, which are working:
interface BRI0/1/0
description backup
ip address negotiated
ip directed-broadcast
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
dialer idle-timeout 300
dialer string 18007931089 class 56k
dialer load-threshold 1 either
dialer-group 1
isdn switch-type basic-ni
isdn spid1 21224226310101
isdn spid2 21224226320101
no peer default ip address
no fair-queue
no cdp enable
ppp authentication pap callin
ppp chap password 7 xxxxxx
ppp pap sent-username storeowd password 7 xxxxx
ppp multilink
ip route 0.0.0.0 0.0.0.0 BRI0/1/0 250
ip route 1.1.1.1 255.255.255.255 BRI0/1/0access-list 101 permit ip any host 1.1.1.1 log
access-list 101 permit tcp any any gt 1 log
access-list 110 remark Traffic from ATA
access-list 110 permit ip 10.193.249.11 0.0.0.4 any
access-list 111 remark Traffic destine to ATA
access-list 111 permit ip any 10.193.249.11 0.0.0.4
dialer-list 1 protocol ip list 101
It appears that the config should work. Would this be an issue on the service provide side with their setup?
Silver
Re: ISDN BRI configuration on 1841
Before using a router with an ISDN basic rate interface (BRI) interface, you must order a correctly configured ISDN BRI line from your local telecommunications service provider.
The ordering process varies from provider to provider and from country to country. However, some general guidelines apply:
•Ask for two channels to be called by one number.
•Ask for delivery of calling line identification, also known as Caller ID or automated number identification (ANI).
•If the router will be the only device attached to the ISDN BRI line, ask for point-to-point service and a data-only line.
•If you plan to connect another ISDN device (such as an ISDN telephone) to the ISDN BRI line through the router, ask for point-to-multipoint service (subaddressing is required) and a voice-and-data line.
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_setup.html#wp53871
Anonymous
N/A
Thanks. I will check that out!
1427
