ISDN BRI couldn't make outgoing calls
Cisco2811 can receive incoming calls but can't make outgoing calls.log shows msgs below:
*Oct 9 06:11:46.951: ISDN BR0/0/0 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
*Oct 9 06:12:21.275: ISDN BR0/0/0 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
*Oct 9 06:13:47.119: ISDN BR0/0/0 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
*Oct 9 06:13:51.119: ISDN BR0/0/0 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
*Oct 9 06:13:55.119: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 0 changed to down
*Oct 9 06:13:55.119: ISDN BR0/0/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Oct 9 06:14:11.343: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/0, TEI 0 changed to up
*Oct 9 06:16:13.451: ISDN BR0/0/0 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
*Oct 9 06:16:27.559: ISDN BR0/0/0 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
*Oct 9 06:16:28.559: ISDN BR0/0/0 **ERROR**: handle_l2d_srq_mail: Layer 1 inactive
Any thoughts?
Re: ISDN BRI couldn't make outgoing calls
Hi Tony
As per the logs it shows the physical layer itself is not up at present.
have you checked up the status of the line using show isdn status ?
also did you try to check the voltage on the isdn line ?
regds
my dear friend
thank you very much for your explanation.I am working with the telco to troubleshoot the ISDN issue.
much appreciated
Tony
put sh isdn status and see layer 1 active or deactivted..then when its up ..still does not work send in the q931 debug output
1013
