Community Member
isdn bri line problem
One of my isdn lines stoped working, it is ISDN backup. Until moday I cannot get any info provider or central side router admin. Does anyone can see from attached debug what could be problem?
thanks!
1 REPLY
Silver
Re: isdn bri line problem
Can't find the reason (unknown reason) from the capture. Check below link may help :
http://www.cisco.com/univercd/cc/td/doc/cisintwk/itg_v1/tr1917.htm
You can also try to enable the "debug ppp negotiation" and "debug ppp authentication" if you use PPP in this link.
Hope this helps.
89
