02-20-2006 12:37 AM - edited 03-03-2019 11:47 AM
Hi All
I have a problem where i have a 512k serial line from a branch Office into my core. I have applied for additional bandwidth but can only get it later in the year due to Telco problems.
I have a PRI used for dial backup and dialin users, can i get the isdn to dial up and bundle with my primary link when a threshold is reached.
02-20-2006 01:10 AM
Yes it is possible though performance wil be hit. You can use backup interface and backup load threshold which will trigger the backup when the threshold configured is reached.
02-20-2006 01:58 AM
I have done that, it seems to acknowledge the fact that the interface needs to come up but it does not dial the interface up
02-20-2006 02:35 AM
hi
Can you post the config of your router here (with public ips and passwds masked )?
regds
02-20-2006 02:54 AM
interface Serial1/0:1
description lancet-jhb
mtu 600
bandwidth 512
backup interface Dialer1
backup load 20 10
ip address (ip address)
encapsulation ppp
ip mroute-cache
load-interval 30
no fair-queue
down-when-looped
no cdp enable
ppp multilink
interface Dialer1
description ISDN Dialup/Backup
no ip address
encapsulation ppp
dialer in-band
dialer idle-timeout 900
dialer string 70113580980
dialer-group 1
no peer default ip address
no fair-queue
no cdp enable
ppp authentication chap
ppp chap hostname PILLMAC
ppp chap password 7 ##############
ppp multilink
02-20-2006 05:08 AM
1) Wonder why you need the multilink on the serial
2) Can you show the routes in the router ? The Route to Dialer should be of the same AD as the route to the Serial. THen it will dial out
02-20-2006 06:19 AM
i accidently left it on i was going to put ppp multilink on the interface for Interleaving
ip route 172.16.0.0 255.255.0.0 192.168.2.5 100 - Serial
ip route 172.16.0.0 255.255.0.0 192.168.3.1 200 - Dialer
Should i have an ip address on my Dialer Interface or unnumbered
02-20-2006 08:59 PM
I would suggest using the ip unnumbered if you are getting a static IP on the dialer. That is the reason why i think it isnt dialing out.
