ISDN Dialer Config.. Problem ???????
I have network of 2500 series router abd as backup we are useing ISDN
on one of the router Cisco 2520 seriies and IOS verions 11.1(10) currently running on it.
have the following config....s (plz chek)
interface Serial0
backup delay 1 1
backup interface Dialer1
ip address 192.168.240.2 255.255.255.252
no ip directed-broadcast
no ip mroute-cache
load-interval 30
interface BRI0
description ***Backup***
no ip address
no ip mroute-cache
encapsulation ppp
isdn all-incoming-calls-v120
ppp authentication chap
interface Dialer1
description ***Backup ISDN Link to XXXX****
ip address 192.168.10.2 255.255.255.252
encapsulation ppp
dialer-group 1
My Question is related with Dialer string
i want to config the dialer string for dialing but it did not except.
plz suggest checking after the above config..
waiting for reply
Re: ISDN Dialer Config.. Problem ???????
Hey, think you are missing a dialer pool command on the dialer interface and a dialer pool-member command on the bri interface. Once you put them in, it will accept the dialer string. So for example, under int dialer 1, dialer pool 1. Then under int bri0, dialer pool-member 1.
You will also need a dialer-list to define the interesting traffic that will trigger the dialer. The dialer-list number should match the dialer-group in the dialer interface, i.e. 1.
However, I don't think that explains not being able to specify a dialer string. The previous poster was right that you need the dialer pool for that. In fact, on my router if you try to define a dialer string before you have set the pool, it says:
%Configure a "dialer in-band" or "dialer pool" first
Kevin Dorrell
Luxembourg
Hi,,
I have tried the dialer pool command but it did not accept it and i have chked its option by (?) but it its not given me pool option in dialer interface ,
plz ckh its IOS version it support the pool command ???
on my all other router pool is config configure and thier IOS version are 12.0(9) and 12.0(5). where this command is configure.
plz ckk it and suggest
Silver
try legacy DDR without dialer profiles:
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a00800b1148.shtml
Hope this helps
Andrea
Thanks for ur answers
I am useing router Cisco 2520 series and IOS verions 11.1(10) currently running on it.
and according to the ur link the supported IOS verison are IOS? Software Release12.1(5)T and the Cisco IOS 12.1(2).
plz suggest solution accoording the aspects ....
Thanks and Regards
Hi Afzaalq
I am also using the same version and its working fine. So i am sending you the configs which i used.
username AAAAAAAAA password 0 BBBBBBBB
interface BRI0/1/0
ip address xxx.xxx.xxx.1 255.255.255.252
encapsulation ppp
load-interval 30
dialer map ip name AAAAAAAAA broadcast 123456789
dialer-group 1
isdn switch-type isdn send-alerting
no shut
dialer-list 1 protocol ip permit
Check that username(AAAAAAAAA) is same when its assigned inside the BRI interface.
Hope this should work fine. If you have any other issues plz let me know.
Rajesh
Hi Rahesh
Thanks alots for the Ans and suggesting a solution Thanks once agian,
One thing more shuold i use same type config..as u sent me (point to point) on both side . or will it work one side ..because fron one side i have config dialer strings.
Thanks for the replay.
139
