ISDN dialer interface MTU change
I have a problem whereby the dialer interface is configured to be of MTU 1600 but changes to 1524 when a call is made.
This is causing the OSPF adjacencies not to form in between. I could use the ip ospf mtu-ignore command, but I would like to know why the above problem is happening
The device is a Cisco2811
flash:c2800nm-advsecurityk9-mz.124-7g.bin
Mayamba
Hall of Fame Super Silver
Re: ISDN dialer interface MTU change
Hello Mayamba,
post the output of
sh int bri0/1/0
sh ip int bri0/1/0
sh int dialer1
sh ip int dialer1
you set the MTU to 1600 to dialer interface and what do you do on the BRI port ?
Hope to help
Giuseppe
I have attached the outputs of the show commands
Hello Mayamba,
the BRI has MTU 1500 B
now the dialer has MTU 1500 B too.
To be able to send a 1600 byte IP packet with DF set (like OSPF database packets) you would need to increase both MTU values
If this is not possible I would suggest to stay with the default values of MTU on both interfaces and OSPF will be fine too.
Hope to help
Giuseppe
286
