Community Member
ISDN does not stay connected more than 20 seconds
I'm testing an ISDN connection and it keeps disconnecting after 20 seconds, could someone help me here??
this is the debug:
*Jul  9 13:36:11: ISDN BR0/2/0 EVENT: UserIdle: callid 0x8123 received ISDN_CALL (0x0)
*Jul  9 13:36:11: ISDN BR0/2/0 EVENT: process_bri_call: call id 0x8123, called_number 5551136, Guid 007562C06502 speed 64, call type DATA, bchan -1 clng_num none
*Jul  9 13:36:11: ISDN BR0/2/0 EVENT: process_rxstate: ces/callid 1/0x8123 calltype 1 HOST_PROCEEDING
*Jul  9 13:36:11: ISDN BR0/2/0 EVENT: process_rxstate: ces/callid 1/0x8123 calltype 1 HOST_PROGRESS
*Jul  9 13:36:27: ISDN BR0/2/0 EVENT: process_rxstate: ces/callid 1/0x8123 calltype 1 HOST_CONNECT
*Jul  9 13:36:27: %ISDN-6-CONNECT: Interface BRI0/2/0:1 is now connected to 5551136 N/A
*Jul  9 13:36:27: ISDN BR0/2/0 EVENT: isdn_neighbor_update: NLCB->State 10
*Jul  9 13:36:27: BR0/2/0:1 PPP: Sending cstate UP notification
*Jul  9 13:36:27: BR0/2/0:1 PPP: Processing CstateUp message
*Jul  9 13:36:27: PPP: Alloc Context [664F1A98]
*Jul  9 13:36:27: ppp276 PPP: Phase is ESTABLISHING
*Jul  9 13:36:27: BR0/2/0:1 PPP: Using dialer call direction
*Jul  9 13:36:27: BR0/2/0:1 PPP: Treating connection as a callout
*Jul  9 13:36:27: BR0/2/0:1 PPP: Session handle[CA000014] Session id[276]
*Jul  9 13:36:27: BR0/2/0:1 LCP: Event[OPEN] State[Initial to Starting]
*Jul  9 13:36:27: BR0/2/0:1 LCP: O CONFREQ [Starting] id 1 len 15
*Jul  9 13:36:27: BR0/2/0:1 LCP:    AuthProto CHAP (0x0305C22305)
*Jul  9 13:36:27: BR0/2/0:1 LCP:    MagicNumber 0x11CCE9ED (0x050611CCE9ED)
*Jul  9 13:36:27: BR0/2/0:1 LCP: Event[UP] State[Starting to REQsent]
*Jul  9 13:36:29: BR0/2/0:1 LCP: O CONFREQ [REQsent] id 2 len 15
*Jul  9 13:36:29: BR0/2/0:1 LCP:    AuthProto CHAP (0x0305C22305)
*Jul  9 13:36:29: BR0/2/0:1 LCP:    MagicNumber 0x11CCE9ED (0x050611CCE9ED)
*Jul  9 13:36:29: BR0/2/0:1 LCP: Event[Timeout+] State[REQsent to REQsent]
*Jul  9 13:36:31: BR0/2/0:1 LCP: O CONFREQ [REQsent] id 3 len 15
*Jul  9 13:36:31: BR0/2/0:1 LCP:    AuthProto CHAP (0x0305C22305)
*Jul  9 13:36:31: BR0/2/0:1 LCP:    MagicNumber 0x11CCE9ED (0x050611CCE9ED)
*Jul  9 13:36:31: BR0/2/0:1 LCP: Event[Timeout+] State[REQsent to REQsent]
*Jul  9 13:36:33: BR0/2/0:1 LCP: O CONFREQ [REQsent] id 4 len 15
*Jul  9 13:36:33: BR0/2/0:1 LCP:    AuthProto CHAP (0x0305C22305)
*Jul  9 13:36:33: BR0/2/0:1 LCP:    MagicNumber 0x11CCE9ED (0x050611CCE9ED)
*Jul  9 13:36:33: BR0/2/0:1 LCP: Event[Timeout+] State[REQsent to REQsent]
*Jul  9 13:36:35: BR0/2/0:1 LCP: O CONFREQ [REQsent] id 5 len 15
*Jul  9 13:36:35: BR0/2/0:1 LCP:    AuthProto CHAP (0x0305C22305)
*Jul  9 13:36:35: BR0/2/0:1 LCP:    MagicNumber 0x11CCE9ED (0x050611CCE9ED)
*Jul  9 13:36:35: BR0/2/0:1 LCP: Event[Timeout+] State[REQsent to REQsent]
*Jul  9 13:36:37: BR0/2/0:1 LCP: O CONFREQ [REQsent] id 6 len 15
*Jul  9 13:36:37: BR0/2/0:1 LCP:    AuthProto CHAP (0x0305C22305)
*Jul  9 13:36:37: BR0/2/0:1 LCP:    MagicNumber 0x11CCE9ED (0x050611CCE9ED)
*Jul  9 13:36:37: BR0/2/0:1 LCP: Event[Timeout+] State[REQsent to REQsent]
*Jul  9 13:36:39: BR0/2/0:1 LCP: O CONFREQ [REQsent] id 7 len 15
*Jul  9 13:36:39: BR0/2/0:1 LCP:    AuthProto CHAP (0x0305C22305)
*Jul  9 13:36:39: BR0/2/0:1 LCP:    MagicNumber 0x11CCE9ED (0x050611CCE9ED)
*Jul  9 13:36:39: BR0/2/0:1 LCP: Event[Timeout+] State[REQsent to REQsent]
*Jul  9 13:36:41: BR0/2/0:1 LCP: O CONFREQ [REQsent] id 8 len 15
*Jul  9 13:36:41: BR0/2/0:1 LCP:    AuthProto CHAP (0x0305C22305)
*Jul  9 13:36:41: BR0/2/0:1 LCP:    MagicNumber 0x11CCE9ED (0x050611CCE9ED)
*Jul  9 13:36:41: BR0/2/0:1 LCP: Event[Timeout+] State[REQsent to REQsent]u all
*Jul  9 13:36:43: BR0/2/0:1 LCP: O CONFREQ [REQsent] id 9 len 15
*Jul  9 13:36:43: BR0/2/0:1 LCP:    AuthProto CHAP (0x0305C22305)
*Jul  9 13:36:43: BR0/2/0:1 LCP:    MagicNumber 0x11CCE9ED (0x050611CCE9ED)
*Jul  9 13:36:43: BR0/2/0:1 LCP: Event[Timeout+] State[REQsent to REQsent]
*Jul  9 13:36:45: BR0/2/0:1 LCP: O CONFREQ [REQsent] id 10 len 15
*Jul  9 13:36:45: BR0/2/0:1 LCP:    AuthProto CHAP (0x0305C22305)
*Jul  9 13:36:45: BR0/2/0:1 LCP:    MagicNumber 0x11CCE9ED (0x050611CCE9ED)
*Jul  9 13:36:45: BR0/2/0:1 LCP: Event[Timeout+] State[REQsent to REQsent]
*Jul  9 13:36:47: BR0/2/0:1 PPP DISC: LCP failed to negotiate
*Jul  9 13:36:47: BR0/2/0:1 PPP: Sending Acct Event[Down] id[126]
*Jul  9 13:36:47: PPP: NET STOP send to AAA.
*Jul  9 13:36:47: BR0/2/0:1 LCP: Event[Timeout-] State[REQsent to Stopped]
*Jul  9 13:36:47: BR0/2/0:1 LCP: Event[DOWN] State[Stopped to Starting]
*Jul  9 13:36:47: BR0/2/0:1 PPP: Phase is DOWN
*Jul  9 13:36:47: ISDN BR0/2/0 EVENT: UserIdle: callid 0x8123 received ISDN_HANGUP (0x1)
*Jul  9 13:36:47: ISDN BR0/2/0 EVENT: isdn_hangup: Hangup call to call id 0x8123 ces = 1
*Jul  9 13:36:47: %ISDN-6-DISCONNECT: Interface BRI0/2/0:1  disconnected from 5551136 , call lasted 20 seconds
*Jul  9 13:36:47: ISDN BR0/2/0 EVENT: process_rxstate: ces/callid 1/0x8123 calltype 1 HOST_DISCONNECT_ACK
*Jul  9 13:36:47: BR0/2/0:1 PPP: Sending cstate DOWN notification
*Jul  9 13:36:47: BR0/2/0:1 PPP: Processing CstateDown message
This is my config:
Router1:
interface BRI0/2/0
ip address 10.44.136.78 255.255.255.252
encapsulation ppp
dialer map ip 10.44.136.77 name core-r1 5551126
dialer map ip 10.44.136.77 name core-r1 5551147
dialer-group 1
isdn switch-type basic-ni
isdn point-to-point-setup
isdn spid1 212555117000 5551170
isdn spid2 212555113600 5551136
ppp authentication chap
end
username core-r1 password 0 cisco
Router 2:
interface BRI0/0/0
ip address 10.44.136.77 255.255.255.252
encapsulation ppp
dialer map ip 10.44.136.78 name sitee-r1 5551170
dialer map ip 10.44.136.78 name sitee-r1 5551136
dialer-group 1
isdn spid1 212555112600 5551126
isdn spid2 212555114700 5551147
end
username sitee-r1 password 0 cisco
Everyone's tags (1)
Hall of Fame Super Gold
I am not sure which router generated this debug output, but I suspect that the issue is on the other router. I see PPP starting LCP and sending this output message over and over
But I do not see any response traffic and the attempt times out. Can you get this type of debug from the other router?
Rick
Community Member
Hi Rick,
The debug comes from Router1, but I have the same debug on the other router as well.
Kelly
388
