05-30-2007 06:55 AM - edited 03-03-2019 05:13 PM
hello All,
here is an out put from my ISDN lines, what could be the problem here?Thanx
COMPANY NAME-ISDN#
*May 30 13:33:22.695: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0052
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98383
Exclusive, Channel 3
Called Party Number i = 0x81, '300'
Plan:ISDN, Type:Unknown
*May 30 13:33:22.699: ISDN Se1/0:15 EVENT: process_rxstate: ces/callid 1/0x4 cal
ltype 2 CALL_INCOMING
*May 30 13:33:22.699: ISDN Se1/0:15 SERROR: isdn_get_guid: Cannot allocate a GUI
D (5)
*May 30 13:33:22.699: ISDN Se1/0:15 EVENT: call_incoming: call_id 0x0004, Guid =
000000004286
COMPANY NAME-ISDN#
*May 30 13:33:22.699: ISDN Se1/0:15 **ERROR**: call_incoming: Received a call id
0x4 with a bad bearercap from <unknown> on b channel 3
ltype 2 CALL_CLEARED
*May 30 13:33:22.699: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0
x8052
Cause i = 0x80D8 - Incompatible destination
05-30-2007 07:03 AM
Is this a router that you use for voice / data or what ?
05-30-2007 07:49 AM
derek
Without knowing a bit more about your environment it is difficult to solve the problem: for example it would be helpful to know what platform this is happening on and some details of its configuration.
I take it from the output that you posted that there is an incoming PRI which is receiving the call and that something about the incoming call is incompatible with the way that the router has been set up. My first guess (without knowing any more details) would be that it was an analog call coming in which can not be handled by the digital facilities of the PRI.
Rick
05-30-2007 07:54 AM
The router is configured for data.
05-30-2007 07:57 AM
derek
So what is the possibility that the incoming call is analog?
Rick
05-30-2007 08:24 AM
The incoming call from the other end is supposed to be digital,the platform is 3700 series and the image on it is 12.4 IOS.
05-30-2007 08:26 AM
derek
So can you find (and post) some details from the 3700 that can confirm (or not) that it is placing digital calls?
Rick
05-30-2007 08:38 AM
here is the running config
hope it helps>
Building configuration...
Current configuration : 2062 bytes
version 12.4
service password-encryption
hostname xxxxx
boot-start-marker
boot-end-marker
card type e1 1
no logging buffered
enable secret 5
no aaa new-model
resource policy
ip subnet-zero
ip cef
isdn switch-type primary-net5
username xxxxxxxx password xxx
username xxxxxxx password 7 xxxxxxxxxxx
username xxxxxxx secret 5 xxxxxxxx
controller E1 1/0
pri-group timeslots 1-31
interface GigabitEthernet0/0
ip address 172.31.x.xxxxx
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
interface BRI0/1/0
no ip address
shutdown
isdn switch-type basic-net3
isdn point-to-point-setup
interface Serial1/0:15
no ip address
encapsulation ppp
dialer pool-member 1 min-link 1 max-link 30
isdn calling-number 560300
isdn bchan-number-order ascending round-robin
ppp authentication chap
ppp multilink
interface Dialer0
description - test isdn loopback cct
ip address 172.21.50.x xxxxxxx
encapsulation ppp
dialer pool 1
dialer remote-name xxxxxxxxxx
dialer idle-timeout 3600
dialer enable-timeout 5
dialer wait-for-carrier-time 60
dialer string 005208641000
dialer load-threshold 127 either
dialer-group 2
no peer default ip address
no cdp enable
ppp multilink
ip classless
ip http server
access-list 140 permit icmp host 172.21.50.253 host 172.21.x.x
access-list 140 deny eigrp any any
dialer-list 2 protocol ip list 140
snmp-server engineID local xxx
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
hostname#
05-30-2007 09:50 AM
can you post debug isdn q931 from the router that is placing the call ?
04-12-2009 07:51 PM
05-30-2007 08:15 PM
Hi ,
Ceck the remote end ISDN number.
The configured nmber on remote end may not be correct...
can paste both routers config.
Satish
05-31-2007 06:47 AM
This has been sorted out, the problem was remote end isdn switch type .
