Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ISDN host_disconnect_ack: Unfound B-channel
I am having problems getting and isdn link up on a cisco 800 series router. I have tested the link on another router and it works fine so the link is good. anyone got any ideas?
Hall of Fame Super Gold
Re: ISDN host_disconnect_ack: Unfound B-channel
What is the configuration and IOS version on both working and not working routers ?
Hi.
version that works - 12.2(4r)
Version thats not working - 12.4
I have replaced the BRI card but still the same problem and error message.
thanks
here is my config
Current configuration : 4236 bytes
version 12.4
service timestamps debug uptime
service timestamps log datetime localtime show-timezone
service password-encryption
no service dhcp
hostname burns
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
no aaa new-model
resource policy
clock timezone GMT 0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
ip cef
no ip dhcp use vrf connected
no ip bootp server
no ip domain lookup
isdn switch-type basic-net3
interface Loopback1
description Management Interface
ip address 172.16.9.212 255.255.255.255
interface FastEthernet0/0
ip address 10.245.0.211 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
speed 100
full-duplex
no cdp enable
standby 10 ip 10.245.0.209
standby 10 priority 95
standby 10 preempt
standby 10 authentication 9uhfdj
interface BRI0/0
no ip address
encapsulation ppp
dialer pool-member 1
isdn point-to-point-setup
isdn caller 8701100
isdn caller 4301111
no cdp enable
ppp authentication chap
ppp multilink
interface Ethernet1/0
ip address 172.16.9.126 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
full-duplex
no cdp enable
interface Dialer0
ip address 172.16.9.58 255.255.255.252
encapsulation ppp
dialer pool 1
dialer remote-name mdrdial
dialer order round-robin
dialer string 4301111
dialer string 8701100
dialer hold-queue 50
dialer load-threshold 128 either
dialer-group 107
no cdp enable
ppp multilink
router eigrp 33
redistribute connected
redistribute static
network 172.16.9.124 0.0.0.3
auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0 180
ip route 172.16.8.116 255.255.255.255 Dialer0
no ip http server
logging facility local1
logging source-interface Loopback1
access-list 1 permit 10.245.0.210 log
access-list 1 permit 172.16.8.212 log
access-list 1 permit 172.16.8.213 log
access-list 1 permit 172.16.8.196 log
access-list 1 permit 172.16.8.197 log
access-list 1 permit 172.16.9.125 log
access-list 1 deny any log
access-list 5 permit 172.16.8.212
access-list 5 permit 172.16.8.213
access-list 5 permit 172.16.8.196
access-list 5 permit 172.16.8.197
access-list 5 deny any log
access-list 101 permit icmp 10.245.0.32 0.0.0.15 10.245.0.0 0.0.0.255
access-list 101 permit udp 10.245.0.32 0.0.0.15 10.245.0.0 0.0.0.255 eq isakmp
access-list 101 permit esp 10.245.0.32 0.0.0.15 10.245.0.0 0.0.0.255
access-list 101 permit udp 10.245.0.32 0.0.0.15 host 224.0.0.2 eq 1985
access-list 101 deny ip any host 255.255.255.255
access-list 101 deny ip any any log
access-list 107 permit icmp 0.0.0.112 255.255.255.0 0.0.0.112 255.255.255.0
access-list 107 deny icmp any any
access-list 107 deny udp any any eq syslog
access-list 107 deny udp any any eq ntp
access-list 107 deny udp any any eq snmp
access-list 107 deny udp any any eq snmptrap
access-list 107 permit ip any any
dialer-list 107 protocol ip permit
RO 5
no cdp run
hello,
I would try to upgrade the route to 12.(4) latest as first step, then do "term mon" and "debug isdn q931" to see what happens when the router tries to place a call. If call is accepted normally, please do "debug ppp packet" to see the why the ppp handshare is failing.
Silver
Hi ,
configure username and password on router.
username mdrdial password XXXX.
You problem will be sorted out after configuring username and password as you are using "chap " for authentication.
Satish
1435
