Community Member
ISDN Huge bill
I replaced the router with a 1750 router with ISDN as backup (T1 primary) I forgot to put backup delay command under serial int (as shown below) the isdn kept connecting/disconnecting within seconds and we got like $23k for isdn bill I am wondering if it was just due to that one line or why will it keep connecting again.. Please help
interface Serial0/0.1 point-to-point
bandwidth 1536
( backup delay 45 60)
backup interface Dialer1
ip address x.y.x.y 255.255.255.248
ip access-group 199 in
no ip redirects
ip nat outside
ip inspect AM-firewall out
no ip mroute-cache
ntp disable
no cdp enable
frame-relay interface-dlci 500 IETF
crypto map AM-region
interface Dialer1
description connected to AM
ip unnumbered Ethernet0/0
encapsulation ppp
no ip route-cache cef
no ip split-horizon
dialer in-band
dialer idle-timeout 60
dialer string 12141112222 class 2JerichoBRI
dialer hold-queue 10
dialer load-threshold 2 either
dialer-group 1
no cdp enable
ppp authentication chap
Apr 27 13:50:20.900: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 12141112222 N/A
Apr 27 13:50:21.396: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
Apr 27 13:50:25.548: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
Apr 27 13:50:25.548: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 12141112222 N/A
Apr 27 13:50:26.048: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
Apr 27 13:50:30.348: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
Apr 27 13:50:30.348: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 12141112222 N/A
Apr 27 13:50:30.848: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
Apr 27 13:50:34.848: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
Hall of Fame Super Silver
Re: ISDN Huge bill
Hello ManjinderPal,
what is the interesting traffic definition
dialer-list 1 ?
I see you have no ip split horizon if you use RIP you need to deny RIP as interesting traffic or it will keep up the link.
However, this quick up/downs look like not ruled by DDR because your idle timeout is 60 seconds it should stay up for 60 seconds after a successful call.
I would use
debug isdn q921
debug isdn q931
debug dialer
to see why these calls are started and why are terminated so quickly
Hope to help
Giuseppe
Community Member
Re: ISDN Huge bill
The dialer list is
dialer-list 1 protocol ip permit
Actually I even the backup interface command was not there.
The quick up/downs really surprises me (split second).. I am running Eigrp through GRE tunnel..
I can't run debug because the line is disconnected.. Any clue
Blue
Re: ISDN Huge bill
Hi:
Giuseppe is right.
You have to figure out which traffic is bringing the dialer interface up. This traffic is known as "interesting traffic." You want to make sure that you create an ACL for your dialer-list that will deny the kind of traffic that the router will broadcast or multicast out all interfaces, like eigrp traffic.
You can take 2 approaches, either permit exactly what you want and let the implicit deny handle the rest. Or you can specifically deny the traffic you know will bring up the interface and permit everything else.
You need to turn on debugging, configure ip accounting, use a sniffer, etc, to examine the ISDN traffic.
By the way, I used to troubleshoot such problems after receiving an incredibly high bill all the time. It can be fun, playing detective. :-)
Good luck.
Victor
Community Member
Re: ISDN Huge bill
but why was it dialing every split second??
Blue
Re: ISDN Huge bill
TURN DEBUGGING ON TO FIND OUT.
Excuse the CAPS, but the recommendation has been made 3 times, so I am wondering if youre seeing it or not. :-)
197
