ISDN Incompatible destination 0x80D804
Hi all,
I have the following issue.
I'm using VIC-2BRI-NT/TE connected to some old NT device.
The outbound calls are working just fine, but inbound calls fails with the following error code 0x80D804.
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Calling Party Number i = 0x1183, '359899980553'
Plan:ISDN, Type:International
Called Party Number i = 0x81, '6490'
Plan:ISDN, Type:Unknown
Oct 17 17:52:56: ISDN BR2/0 Q921: User TX -> INFO sapi=0 tei=68, ns=0 nr=0
Oct 17 17:52:56: ISDN BR2/0 Q931: RELEASE_COMP pd = 8 callref = 0xC1
Cause i = 0x80D804 - Incompatible destination
Can someone give me the exact description of 0x80D804.
I know that this is a bearer cap problem, speed or transfer cappability, but i think i have tried everything and nothing.
Thanks!
Re: ISDN Incompatible destination 0x80D804
80 at the beginning of your cause code usually means there is a problem with the router. Can you post the config of your router ? Not knowing what exactly you have configured, you might want to try and add 'speed 56' to the end of your dialer map statement...
GNT
Hi GNT/Anyone:
I am also having a similar issue.
I am using HWIC-4B-S/T connected to Mistel NT device that seems to work well when tested with isdn phone.
inbound voice calls to the router (2810isr [c2801.ipvoicek9-mz-151-2.T1.bin]) are failing with the following error:
        Channel ID i = 0x89
                Exclusive, B1
        Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
        Called Party Number i = 0xA1, '20319146'
                Plan:ISDN, Type:National
        Sending Complete
*Nov  6 03:51:28.572: IS
Nov  6 03:51:28.576: ISDN BR0/3/0 EVENTd: host_incoming_call: voice_answer_data = FALSE call type is VOICE ALAW
*Nov  6 03:51:28.576: ISDN BR0/3/0 EVENTd: host_incoming_call: Received a VOICE call from on B1 at 64 Kb/s
*Nov  6 03:51:28.576: ISDN BR0/3/0 EVENTd: host_incoming_call: Accepting call call id 0x32
*Nov  6 03:51:28.580: ISDN BR0/3/0 EVENTd: host_incoming_call: Sending event  to
Call setup is okay but error is coming during the call acceptance process.
We are able to pass data through fine
Any ideas? we tried everything
Thanks!
Hall of Fame Super Gold
HWIC-4B-S/T does not NOT support voice calls, and there is nothing that can be done so that it can.
You must use VIC2-2BRI-NT/TE and PVDM2-xx to support voice calls on BRI.
Hi there and thanks!
I was afraid that might be the case. I will try and change cards and see what happens.
I just googled and went through the Cisco website and the nearest I can find to the interface you've suggested are VIC-2BRI-S/T-TE, VIC-2BRI-NT/TE and VIC2-2BRI-NT/TE. I can't find VIC2-2BRI-S7T, might you have a direct link to somewhere I can find it?
I have  PVDM2-32 on that slot, will that work or do i need to up it up?
Thanks again.
The P/N is VIC2-2BRI-NT/TE.
Thank you for the nice rating and good luck!
ok!
i will try that with PVDM2-32 and let you know. thanks again.
Hi all-
Has anyone out there deployed a ISDN BRI to IP voice network using Cisco 2801?
We have VIC2-2BRI-NT/TE card on a 2801 isr. The first challenge is that the Telco is providing a 2-wire endpoint for each pair of ISDN BRI. When we try to connect the line directly to the card using a RJ11 to RJ45 cable, nothing seems to reaches the interface/router. However when we connect ISDN to external [Mistel] Network Terminal and use the [external] NT's RJ45 output to connect to the interface card we see the call but audio is very scratchy and called party does not get audio - (perhaps because call is going through 2 NTs, assuming this card has inbuilt NT)
Is the VIC2-2BRI-NT/TE our best option? Do we have other options especially as I already have external NTs?
The available ISDN parameters are:
B channel 64 kbps
2b + d (b = voice; d=data)
ISDN type = euro
Uses layer2 protocol
Would greatly appreciated any suggestions or anyone knows of another interface that does not have inbuilt NT as we already have external NT purchased
Thanks in advance!!!
Of course you must use an external NT, as the documentation indicate when you take the time to read it. It is actually inferable form the part name also.
Assuming you have not damaged hardware, poor audio is due to misconfiguration of companding-type under voice-port. Again, something that. documentation or a search would have revealed to you.
hi-
am not sure what documentaion are you refering to, might you have a link or a way i can access the info?
Search "companding type" and you will find.
2267
