06-09-2006 09:39 PM - edited 03-03-2019 12:57 PM
I am using cisco 1841 rouetr with 2 WIC-1B-S/T-V3 cards as the central router ,the configuration is such that only central router can dial to the client location router using ISDN connectivity .
Issue is we are switching off the router daily evening ,while switching on the router the ISDN line is not activated ,the layer 1 is coming up only if I dial to the central location ISDN number from a land phone .
At the service provider side they are having seimens ISDN switch , the NT unit used is MROTECK NT1.
so how to activate the layer 1 of the bri interface active automatically
06-11-2006 07:13 AM
Just to make sure that i understood your case.
When the router switch ON, and you issue show isdn status command, Layer1 deactivated, right?
It will be UP only if you place an analog phone at the analog ports at the ISDN NT, or i think if you issue "clear interface bri 0/0/0" it will be activated and UP. I think this problem related to your ISP, either setting the ISDN switch type, or (I recommend this) that the ISDN NT type.
Could you please change the NT and try again?!
I'm waiting your update!
Abd Alqader
06-15-2006 08:53 PM
I tried by giving the command clear interface bri and by changing the NT unit also but stillthe same status ,layer 1 is deactivated
ISDN switch type specified is basic net 3
waiting for your reply
thanks and regards
Retheesh
06-15-2006 09:39 PM
hi
can you post out the config pertaining to the ISDN bri interface & connectivity..
regds
06-19-2006 05:06 AM
Please find configuration for the router
interface BRI0/0/0
no ip address
encapsulation ppp
dialer pool-member 1
dialer pool-member 7
dialer pool-member 6
dialer pool-member 5
dialer pool-member 2
dialer pool-member 3
dialer pool-member 4
isdn switch-type basic-net3
isdn point-to-point-setup
no cdp enable
ppp multilink
interface BRI0/1/0
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface Dialer1
description venalla
ip address 10.0.250.9 255.255.255.252
encapsulation ppp
dialer pool 1
dialer idle-timeout 180
dialer fast-idle 10
dialer string 2807467
dialer-group 1
ppp authentication pap
ppp pap sent-username head password 0 cisco
ppp multilink
interface Dialer2
description cable
ip address 10.0.250.13 255.255.255.252
encapsulation ppp
dialer pool 2
dialer fast-idle 10
dialer string 04222656785
dialer-group 1
ppp multilink
interface Dialer3
description emw
ip address 10.0.250.17 255.255.255.252
encapsulation ppp
dialer pool 3
dialer fast-idle 10
dialer string 04222573808
dialer-group 1
ppp multilink
interface Dialer4
description coimbatore
ip address 10.0.250.21 255.255.255.252
encapsulation ppp
dialer pool 4
dialer fast-idle 10
dialer string 04222430751
dialer-group 1
ppp multilink
interface Dialer5
description godown
ip address 10.0.250.25 255.255.255.252
encapsulation ppp
dialer pool 5
dialer fast-idle 10
dialer string 08025608455
dialer-group 1
no peer default ip address
ppp multilink
interface Dialer6
description bangalore
ip address 10.0.250.29 255.255.255.252
encapsulation ppp
dialer pool 6
dialer fast-idle 10
dialer string 08025218810
dialer-group 1
no cdp enable
ppp multilink
interface Dialer7
description hyderbad
ip address 10.0.250.33 255.255.255.252
encapsulation ppp
dialer pool 7
dialer fast-idle 10
dialer string 04024222441
dialer load-threshold 4 either
dialer-group 1
no cdp enable
ppp multilink
please reply asap
06-19-2006 01:18 PM
Why you are using that number of dialer-pools?
use as example dialer-pool 1 and use it in all the interfaces.
interface BRI0/0/0
no ip address
encapsulation ppp
no cdp enable
ppp multilink
interface BRI0/1/0
no ip address
encapsulation ppp
no cdp enable
ppp multilink
And at the dialer interfaces you can assign either the interface use bri 0/0/0 or bri 0/1/0
But i think your problem is at the physical or layer2. Since once you are use the analog line at the NT, the line gets UP!
Abd Alqader
06-20-2006 01:41 AM
it is not the dialer pool which is creating the problem
06-20-2006 11:12 AM
I know, as i told you before, it is either physical connectivity or layer2 (communication between the card and the ISDN switch).
Abd Alqader
06-21-2006 11:44 PM
Physical connectivity was checked ,status was ok,
the bri module used is WIC B S/T1-V3 whether any configuration is required to automatically make the layer 1 active
