05-19-2008 08:13 PM - edited 03-03-2019 10:00 PM
HI,
I have a PRI line whcih is newly configured, but the controller is going up and down. Is it because of the configuration issue or the hardware failure. The clock is set as external.
05-19-2008 09:09 PM
HI, [Pls RATE if HELPS]
Refer this Link below for troubleshooting"
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00801509d7.shtml
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
05-19-2008 09:30 PM
Thanks Guru Prasad,
I have done the configuration, but the controller E1 is going up and down. Its not stable.
05-19-2008 10:16 PM
HI, [Pls Rate if HELPS]
Refer Link below and Troubleshoot the E1 Layer1 Issue:
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800fb754.shtml
Pls Rate if Helps => Use the Rating System.
Best Regards,
Guru Prasad R
05-19-2008 11:36 PM
Thanks Guru Prasad,
The controller came up after I changed the framing and CRC commands and its stable.
Eldo
