Community Member
ISDN issue
hi i got 1841 rtr ios 12.3 8r
when i do isdn test call i get follwoing error:
ASSERTION FAILED: file "../chips/gt96k/gt96k_timer.c", line 771
bir conf is as below:
interface BRI0/1/0
ip address negotiated
ip nat outside
encapsulation ppp
no ip mroute-cache
shutdown
dialer idle-timeout 1000
dialer string XXXXXX
dialer-group 1
isdn switch-type basic-5ess
isdn point-to-point-setup
ppp authentication pap callin
ppp pap sent-username XXX password 0 XXX
Silver
Re: ISDN issue
It is in shutdown mode. I dont think it should make calls
Hall of Fame Super Gold
Re: ISDN issue
The previous post is quite correct that with the interface in shutdown mode it should not make any calls.
If you activate the interface with no shutdown and still get this kind of error, I believe that errors with ASSERTION FAILED are software problems rather than hardware problems.
Rick
133
