ISDN PRA LINES
I have 2600 router with two port E1 ISDN PRA controller. From ISDN provider point ov view these two lines are on the same group with 600-699 numbers on them. Is it possible that I somehow from my side controles wich number will each line answer? For example I want lin 0 to answer to 600 number and line 1 to answer to 601.
thanks!
1 REPLY
Hall of Fame Super Gold
Re: ISDN PRA LINES
yes you can do that, but since the lines are in the same group, you risk to loose calls if you don't answer. That is, a call for 601 can land on line 0 and if you don't answer it, you have to wait for the caller to call again and land on line 1.
The command is "isdn answer1 ..."
307
