Webcast-Catalyst9k
ISDN Pri and Bri Remote Access
Hi.
We have a 3640 router used as access-server.
It's connected to an ISDN Pri line, and all works properly.
Now we need Pri line for other purposes, and our RAS users are very few.
So we have attached router to a BRI connection, and configured this to achieve same work (remote access connection).
But this doesn't work, when we try to connect from a PC to the BRI line, error is:
cisco3640#
00:03:22: ISDN BR2/0: RX <- SETUP pd = 8 callref = 0x6E
00:03:22: Bearer Capability i = 0x9090A3
00:03:22: Channel ID i = 0x8A
00:03:22: Progress Ind i = 0x8083 - Origination address is non-ISDN
00:03:22: Calling Party Number i = 0x00, 0xA3, Plan:Unknown, Type:Unknown
00:03:22: Called Party Number i = 0xA1, '1119520806', Plan:ISDN, Type:National
00:03:22: High Layer Compat i = 0x9181
30064771072:00:12884901888: ISDN BR2/0: Event: Received a VOICE call from <unknown> on B2 at 64 Kb/s
30064771072:00:12884901888: ISDN BR2/0: Event: Accepting the call id 0x3
00:03:22: ISDN BR2/0: TX -> CALL_PROC pd = 8 callref = 0xEE
cisco3640#
00:03:22: ISDN BR2/0: TX -> ALERTING pd = 8 callref = 0xEE
00:03:22: ISDN BR2/0: TX -> DISCONNECT pd = 8 callref = 0xEE
00:03:22: Cause i = 0x8090 - Normal call clearing
00:03:22: ISDN BR2/0: RX <- RELEASE pd = 8 callref = 0x6E
00:03:22: ISDN BR2/0: TX -> RELEASE_COMP pd = 8 callref = 0xEE
configuration is the same for both lines:
interface Loopback1
ip address 192.168.70.1 255.255.255.0
no ip unreachables
interface Serial1/0:15
ip unnumbered Loopback1
no ip unreachables
encapsulation ppp
ip tcp header-compression passive
dialer pool-member 1
isdn switch-type primary-net5
isdn incoming-voice modem
no fair-queue
no cdp enable
ppp callback permit
ppp authentication chap dial-in
interface BRI2/0
no ip unreachables
encapsulation ppp
isdn switch-type basic-net3
no peer default ip address
no fair-queue
no cdp enable
ppp callback permit
interface Virtual-Template1
no ip unreachables
peer default ip address pool ftp
ppp callback permit
interface Group-Async1
no ip unreachables
encapsulation ppp
no ip route-cache
no ip mroute-cache
keepalive 10
async default routing
async mode interactive
ppp callback permit
group-range 1 24
We have tried to change ios to last release yet.
thanks a lot for any suggestions.
Daniele
Hall of Fame Super Gold
Re: ISDN Pri and Bri Remote Access
Daniele
I believe that the issue is that while the PRI was able to accept both digital and analog calls, the BRI is accepting only digital calls. The incoming call is not digital as shown in this output:
and in this output:
ISDN BR2/0: Event: Received a VOICE call from on B2 at 64 Kb/s
Rick
Thanks for your suggestion.
I've tried without PRI card, but it doesn't work. Error message is:
cisco3640#
21:10:57: ISDN BR2/0: RX <- SETUP pd = 8 callref = 0x71
21:10:57: Sending Complete
21:10:57: Bearer Capability i = 0x8090A3
21:10:57: Channel ID i = 0x8A
21:10:57: Calling Party Number i = 0x00, 0xA3, Plan:Unknown, Type:Unknown
21:10:57: Called Party Number i = 0xA1, '1119520806', Plan:ISDN, Type:National
21:10:57: ISDN BR2/0: Event: Received a VOICE call from on B2 at 64 Kb/s
21:10:57: ISDN BR2/0: Event: Accepting the call id 0x6
Jan 13 13:53:27.473: %CSM-1-HWREV: The T1 or E1 network module is incompatible with the digital modems: MODEM_REPORT
cisco3640#
21:10:57: ISDN BR2/0: TX -> CALL_PROC pd = 8 callref = 0xF1
21:10:57: ISDN BR2/0: TX -> DISCONNECT pd = 8 callref = 0xF1
21:10:57: Cause i = 0x80AC - Requested circuit/channel not available
21:10:57: ISDN BR2/0: RX <- RELEASE pd = 8 callref = 0x71
21:10:57: Cause i = 0x8090 - Normal call clearing
21:10:58: ISDN BR2/0: TX -> RELEASE_COMP pd = 8 callref = 0xF1
cisco3640#
Do I have to reconfigure micamodem?
This is the error now:
cisco3640#
00:03:59: ISDN BR2/0 Q931: RX <- SETUP pd = 8 callref = 0x11
Sending Complete
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Calling Party Number i = 0x00A3, N/A
Sending Complete
00:03:59: ISDN BR2/0 **ERROR**: accept_incoming_csm_call: modem problem Requested circuit/channel not available(0x2C): b channel 1, call id 0x6
00:03:59: ISDN BR2/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x91
Channel ID i = 0x8A
cisco3640#
00:03:59: ISDN BR2/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x91
00:03:59: ISDN BR2/0 Q931: RX <- RELEASE pd = 8 callref = 0x11
00:03:59: ISDN BR2/0 **ERROR**: host_disconnect_ack: VOICE ERROR: Invalid CSM info(0xFB): b channel 1, call id 0x6
00:03:59: ISDN BR2/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x91
cisco3640#unde all
All possible debugging has been turned off
do you have "modem dialin" and "no exec under" line xx-yy ?
Yes I have.
And Remote Access from Primary ISDN line work properly.
This error come on only if I try to connect from BRI lines.
Is it possible that Pri use modems and take them not possible to use anyway?
What is the WIC HW revision ? check "show diag". There is a minimum to work with the DM.
By coincidence, just yesterday I prepared such a configuration, and it was working fine.
But I didn't had a PRI card in router.
355
