10-09-2006 01:55 AM - edited 03-03-2019 02:16 PM
An ISDN PRI periodically hangs, 2 or 3
times a week. The fix is to shutdown the controller and no shut.
IOS 12.3(14)T7,2651XM.
ISDN q921 debugs turned on when problem
occurs. It shows that after this debug
Aug 15 05:34:44.075:ISDN Se0/0:15 Q921: User TX -> REJ sapi=0 tei=0 nr=68\
par the router never sends another User TX -> RRp and only sends TX -> RRf
Any suggestions on how to stop it happening?
10-13-2006 05:20 AM
IOS gateway does not detect the correct ns value for a retransmitted q921 info message. this causes the t200 timer to increment which eventually will cause the E1 to reset.
10-13-2006 07:32 PM
Hi Thomas
Thank you so much for the explanation.Much appreciated.
The problem is fixed by the telco.They had layer 2 issue.
Have a nice weekend.
Tony
