Community Member
ISDN PRI on 7609
Dear All,
Does Cisco 7609 router support ISDN PRI configuration with 1 Enhanced FlexWAN controller (8 E1) and PA-MC-8TE1+ installed ?
confirm ..
aman
Re: ISDN PRI on 7609
Hi Aman
As per the supporting doc it doesn't have the support for a PRI card..
do check this link for more info on the cards supported by the Enhanced FlexWan Module..
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a00801df1d9.html
regds
Hall of Fame Super Gold
PA-MC-8TE1+ is (also) a PRI card, and is supported on the enh. flexwan.
I don't know (haven't searched) if ISDN code is present in the 76xx / enh. flexwan.
Hope this helps, if so please rate post!
Community Member
Thanks .
I have also been able to find the document which learly says that ISDN is not supported on 7600 & 7304 platforms
161
