05-26-2006 05:07 AM - edited 03-03-2019 12:49 PM
I have configured my E1 controller for PRI. The line is up. But i am unable to open the interface to configure it. When i am issuing the command interface serial2/0:1 the following error is displyed
% cannot access B-channel interfaces.
The configuration for PRI as has been done is :(global configuration)
isdn switch-type primary-net5
and
the controller configuration are as follows:
controller E1 2/0
framing NO-CRC4
pri-group timeslots 1-31
description *** PRI 22839972 ***
Kindly help me about where is the problem.
05-26-2006 05:16 AM
Hi, try issuing the command interface serial2/0:15 and go from there.
Channel 15 is the D channel here.
Hope this helps.
05-26-2006 11:57 AM
For a ISDN PRI, you can only configure the D-channel; that is S2/0:15.
eg.
interface Serial2/0:15
description "isdn pri no. is 1234567"
no ip address
encapsulation ppp
dialer pool-member 1
no cdp enable
ppp authentication chap
ppp multilink
Use Dialer pool-member in above D-channel configuration if you want to configure dialer profiles as per your needs. Then do remember to add "dialer pool 1" in all the dialer profiles.
Pls do rate all helpful posts.
05-26-2006 09:05 PM
I have configured the s2/0:15 interface
But still when I try to configure the s2/0:1 its giving the same error
05-28-2006 11:21 PM
You will be not able to configure B channels. As per my understanding you want to configure seperate interfaces for individual location.
You can create dialer & make it the pool member of PRI D Interface i.e. s2:15.
I think this will solve your problem.
Do let me know if you still have any query.
Madhur
05-29-2006 02:42 AM
Hi Madhur
Yes I want to configure for multiple locations do i need to create dialer pool on the PRI D Interface i.e.s2:15?
05-29-2006 09:04 PM
If you are configuring different profiles for different locations then you need to create induvidual dialers which should be brought into the dialer pool configured under the dialer interfaces and respective dialer pool-member configured under the PRI Interface (S 2:15)..
you can refer this link for the same which deals with configuring a T1 PR1 link..
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_configuration_example09186a0080094559.shtml
regds
