I am trying to configure it as the ISDN switch, and route calls for two Cisco routers, but I couldn't get it working. I am hoping someone here has been worked with one of the AccessSwitch...
I can see the Layer 1 and 2 are up, but the layer 3 won't work properly. One weird thing is both of the router got the same TEI, they are all 64. I am thinking I might screwed somewhere like dial-plan or something in Madge, but I am not sure... I would appreciate any help! The following is some configuration and debug information.
Router R5, connect to BRI Port 2
interface BRI0
ip address 192.168.10.3 255.255.255.0
encapsulation ppp
dialer map ip 192.168.10.5 name R8 broadcast 666666
dialer load-threshold 1 either
dialer-group 1
isdn switch-type basic-5ess
ppp multilink
dialer-list 1 protocol ip permit
R5#sh isdn status
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = basic-5ess
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 64, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
R5#debug isdn q921
ISDN Q921 packets debugging is on
R5#ping 192.168.10.5
Sending 5, 100-byte ICMP Echos to 192.168.10.5, timeout is 2 seconds:
02:25:40: ISDN BR0: TX -> INFOc sapi=0 tei=64 ns=3 nr=5 i=0x08010505040288901801832C06363636363636
02:25:41: ISDN BR0: RX <- RRr sapi=0 tei=64 nr=4
02:25:41: ISDN BR0: RX <- INFOc sapi=0 tei=64 ns=5 nr=4 i=0x0801855A080282B4
02:25:41: ISDN BR0: TX -> RRr sapi=0 tei=64 nr=6.....
Success rate is 0 percent (0/5)
R5#debug isdn q931
ISDN Q931 packets debugging is on
02:26:18: ISDN BR0: TX -> SETUP pd = 8 callref = 0x06
02:26:18: Bearer Capability i = 0x8890
02:26:18: Channel ID i = 0x83
02:26:18: Keypad Facility i = '666666'
02:26:18: ISDN BR0: RX <- RELEASE_COMP pd = 8 callref = 0x86
02:26:18: Cause i = 0x82B4 - Service operation violated.....
