ISDN problems
I cannot established a backup call between a 7200 and a 1721 because the connection is UP only for 20 seconds and then it's disconnected!!
The log on 7200 say:
*Oct 27 00:10:23.980: %DIALER-6-UNBIND: Interface Se2/0:0 unbound from profile Di1
*Oct 27 00:10:24.404: %DIALER-6-BIND: Interface Se2/0:4 bound to profile Di1
*Oct 27 00:10:24.408: %LINK-3-UPDOWN: Interface Serial2/0:4, changed state to up
*Oct 27 00:10:24.408: %ISDN-6-CONNECT: Interface Serial2/0:4 is now connected to 123456 N/A
*Oct 27 00:10:44.944: %ISDN-6-DISCONNECT: Interface Serial2/0:4 disconnected from 123456, call lasted 20 seconds
*Oct 27 00:10:44.944: %LINK-3-UPDOWN: Interface Serial2/0:4, changed state to down
*Oct 27 00:10:44.948: %DIALER-6-UNBIND: Interface Se2/0:4 unbound from profile Di1
*Oct 27 00:10:45.340: %DIALER-6-BIND: Interface Se2/0:8 bound to profile Di1
*Oct 27 00:10:45.340: %LINK-3-UPDOWN: Interface Serial2/0:8, changed state to up
*Oct 27 00:10:45.340: %ISDN-6-CONNECT: Interface Serial2/0:8 is now connected to 123456 N/A
*Oct 27 00:11:05.848: %ISDN-6-DISCONNECT: Interface Serial2/0:8 disconnected from 123456, call lasted 20 seconds
*Oct 27 00:11:05.848: %LINK-3-UPDOWN: Interface Serial2/0:8, changed state to down
*Oct 27 00:11:05.848: %DIALER-6-UNBIND: Interface Se2/0:8 unbound from profile Di1
*Oct 27 00:11:06.248: %DIALER-6-BIND: Interface Se2/0:12 bound to profile Di1
*Oct 27 00:11:06.252: %LINK-3-UPDOWN: Interface Serial2/0:12, changed state to up
*Oct 27 00:11:06.252: %ISDN-6-CONNECT: Interface Serial2/0:12 is now connected to 123456 N/A
*Oct 27 00:11:26.772: %ISDN-6-DISCONNECT: Interface Serial2/0:12 disconnected from 123456, call lasted 20 seconds
*Oct 27 00:11:26.772: %LINK-3-UPDOWN: Interface Serial2/0:12, changed state to down
*Oct 27 00:11:26.772: %DIALER-6-UNBIND: Interface Se2/0:12 unbound from profile Di1
*Oct 27 00:11:27.168: %DIALER-6-BIND: Interface Se2/0:16 bound to profile Di1
*Oct 27 00:11:27.168: %LINK-3-UPDOWN: Interface Serial2/0:16, changed state to up
*Oct 27 00:11:27.168: %ISDN-6-CONNECT: Interface Serial2/0:16 is now connected to 123456 N/A
*Oct 27 00:11:47.664: %ISDN-6-DISCONNECT: Interface Serial2/0:16 disconnected from 123456 , call lasted 20 seconds
*Oct 27 00:11:47.664: %LINK-3-UPDOWN: Interface Serial2/0:16, changed state to down
*Oct 27 00:11:47.664: %DIALER-6-UNBIND: Interface Se2/0:16 unbound from profile Di1
*Oct 27 00:11:48.068: %DIALER-6-BIND: Interface Se2/0:20 bound to profile Di1
*Oct 27 00:11:48.068: %LINK-3-UPDOWN: Interface Serial2/0:20, changed state to up
*Oct 27 00:11:48.068: %ISDN-6-CONNECT: Interface Serial2/0:20 is now connected to 123456 N/A
*Oct 27 00:12:08.560: %ISDN-6-DISCONNECT: Interface Serial2/0:20 disconnected from 123456, call lasted 20 seconds
*Oct 27 00:12:08.560: %LINK-3-UPDOWN: Interface Serial2/0:20, changed state to down
*Oct 27 00:12:08.564: %DIALER-6-UNBIND: Interface Se2/0:20 unbound from profile Di1
*Oct 27 00:12:08.964: %DIALER-6-BIND: Interface Se2/0:24 bound to profile Di1
*Oct 27 00:12:08.968: %LINK-3-UPDOWN: Interface Serial2/0:24, changed state to up
*Oct 27 00:12:08.968: %ISDN-6-CONNECT: Interface Serial2/0:24 is now connected to 123456 N/A
*Oct 27 00:12:29.436: %ISDN-6-DISCONNECT: Interface Serial2/0:24 disconnected from 123456, call lasted 20 seconds
*Oct 27 00:12:29.436: %LINK-3-UPDOWN: Interface Serial2/0:24, changed state to down
*Oct 27 00:12:29.436: %DIALER-6-UNBIND: Interface Se2/0:24 unbound from profile Di1
*Oct 27 00:12:29.848: %DIALER-6-BIND: Interface Se2/0:28 bound to profile Di1
*Oct 27 00:12:29.848: %LINK-3-UPDOWN: Interface Serial2/0:28, changed state to up
*Oct 27 00:12:29.848: %ISDN-6-CONNECT: Interface Serial2/0:28 is now connected to 123456 N/A
Re: ISDN problems
Can u post the config?
The tel no:123456 is masked by u?
JD
Re: ISDN problems
It's all resolved! I had upgrade IOS on 7200 then I reboot the 1721 and now all is ok
PS. 123456 it's a masked number
Bye bye and thanks the same!!
132
