ISDN problems
Hi, I have a serious problem with ISDN backup.
The call is up for only few seconds.
But the main problem is another, if i do a sh logging i have:
Dec 20 00:02:08.793: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 91 changed to down
Dec 20 01:46:30.580: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 92 changed to up
Dec 20 01:46:43.816: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 92 changed to down
Dec 20 02:02:29.496: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 93 changed to up
Dec 20 02:02:43.800: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 93 changed to down
Dec 20 06:02:29.535: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 94 changed to up
Dec 20 06:02:43.735: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 94 changed to down
Dec 20 06:18:29.543: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 95 changed to up
Dec 20 06:18:43.731: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 95 changed to down
Dec 20 09:45:03.354: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 96 changed to up
Dec 20 09:45:13.678: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 96 changed to down
Dec 20 10:22:36.962: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 97 changed to up
Dec 20 10:22:48.666: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 97 changed to down
Dec 20 10:38:29.558: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 98 changed to up
Dec 20 10:38:43.670: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 98 changed to down
Dec 20 11:42:53.062: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 99 changed to up
Dec 20 11:43:03.646: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 99 changed to down
Dec 20 12:17:23.118: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 100 changed to up
Dec 20 12:17:33.634: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 100 changed to down
Dec 20 12:55:33.082: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 101 changed to up
Dec 20 12:55:43.622: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 101 changed to down
Dec 20 13:31:47.477: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 102 changed to up
Dec 20 13:31:58.621: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 102 changed to down
Dec 20 13:33:30.629: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 103 changed to up
Dec 20 13:33:43.613: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 103 changed to down
Dec 20 13:34:54.997: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 104 changed to up
Dec 20 13:35:08.617: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 104 changed to down
Dec 20 13:49:00.513: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 107 changed to up
Dec 20 13:49:13.429: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 107 changed to down
Dec 20 13:58:47.673: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 108 changed to up
Dec 20 13:58:58.429: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 108 changed to down
Dec 20 14:44:29.361: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 109 changed to up
Dec 20 14:44:43.433: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 109 changed to down
Dec 20 15:00:29.365: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 111 changed to up
Dec 20 15:00:43.409: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 111 changed to down
Dec 20 15:53:04.021: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 64 changed to up
Dec 20 15:53:18.437: %ISDN-3-LAYER2_DOWN: Layer 2 for Interface BR0, TEI 64 changed to down
What means???? are there problems with ISDN LINE ????
1 ACCEPTED SOLUTION
VIP Purple
Re: ISDN problems
if the real name of the calling router is not configured on the called router, you need to define the username you have defined, 'send' in your case, in the CHAP configuration. Therefore, you need to configure:
ppp chap hostname send
ppp chap password send
on the calling router.
GP
VIP Purple
Re: ISDN problems
this could be an authentication problem. Can you post the configurations of both your routers ?
GP
Re: ISDN problems
Router 1721 (router that sending call)
version 12.3
service password-encryption
hostname Sendigcall
boot-start-marker
boot system flash 1721.bin
boot-end-marker
logging buffered 10000 debugging
enable secret 5
enable password 7
username send password 7
username receive password 7
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
no ftp-server write-enable
isdn switch-type basic-net3
isdn logging
interface Loopback0
ip address aaa.aaa.aaa.aaa 255.255.255.255
ip nat outside
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
isdn send-alerting
isdn sending-complete
no fair-queue
no cdp enable
ppp authentication chap callin
interface FastEthernet0
ip address 192.168.1.254 255.255.255.0
ip nat inside
speed auto
interface Serial0
no ip address
encapsulation frame-relay IETF
no fair-queue
interface Serial0.1 point-to-point
ip address bbb.bbb.bbb.bbb 255.255.255.252
ip nat outside
frame-relay interface-dlci number
interface Dialer1
ip address ccc.ccc.ccc.ccc 255.255.255.252
ip nat outside
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer remote-name receive
dialer idle-timeout 3
dialer string 06.......
dialer watch-group 1
no cdp enable
router eigrp 1
redistribute connected
network bbb.bbb.bbb.bbb 0.0.0.3
network ccc.ccc.ccc.ccc 0.0.0.3
auto-summary
ip nat inside source list 101 interface Loopback0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 bbb.bbb.bbb.bbb
ip route 0.0.0.0 0.0.0.0 Dialer1 250
no ip http server
no ip http secure-server
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
dialer watch-list 1 ip 192.168.199.0 255.255.255.0
dialer watch-list 1 delay route-check initial 10
dialer watch-list 1 delay disconnect 10
Re: ISDN problems
This is the debug q931 ans q921 and isdn error on the router that making call
Dec 20 17:51:27.008: ISDN BR0 Q921: User TX -> RR sapi=0 tei=66 nr=1
Dec 20 17:51:27.320: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=66, ns=1 nr=1
Dec 20 17:51:27.320: ISDN BR0 Q931: CONNECT pd = 8 callref = 0x90
Dec 20 17:51:27.320: ISDN BR0 Q921: User TX -> RR sapi=0 tei=66 nr=2
Dec 20 17:51:27.324: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
Dec 20 17:51:27.328: %DIALER-6-BIND: Interface BR0:1 bound to profile Di1
Dec 20 17:51:27.328: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 06........ N/A
Dec 20 17:51:27.332: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=66, ns=1 nr=2
Dec 20 17:51:27.332: ISDN BR0 Q931: CONNECT_ACK pd = 8 callref = 0x10
Dec 20 17:51:27.384: ISDN BR0 Q921: User RX <- RR sapi=0 tei=66 nr=2
Dec 20 17:51:29.388: %ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from 06........ , call lasted 2 seconds
Dec 20 17:51:29.392: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=66, ns=2 nr=2
Dec 20 17:51:29.392: ISDN BR0 Q931: DISCONNECT pd = 8 callref = 0x10
Cause i = 0x8090 - Normal call clearing
Dec 20 17:51:29.492: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=66, ns=2 nr=3
Dec 20 17:51:29.492: ISDN BR0 Q931: RELEASE pd = 8 callref = 0x90
Dec 20 17:51:29.496: ISDN BR0 Q921: User TX -> RR sapi=0 tei=66 nr=3
Dec 20 17:51:29.500: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
Dec 20 17:51:29.500: %DIALER-6-UNBIND: Interface BR0:1 unbound from profile Di1
Dec 20 17:51:29.504: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=66, ns=3 nr=3
Dec 20 17:51:29.504: ISDN BR0 Q931: RELEASE_COMP pd = 8 callref = 0x10
Dec 20 17:51:29.592: ISDN BR0 Q921: User RX <- RR sapi=0 tei=66 nr=4
Dec 20 17:51:29.592: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=66, ns=4 nr=3
Dec 20 17:51:29.596: ISDN BR0 Q931: SETUP pd = 8 callref = 0x11
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x83
Called Party Number i = 0x80, 06........
Plan:Unknown, Type:Unknown
Sending Complete
Dec 20 17:51:29.680: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=66, ns=3 nr=5
Dec 20 17:51:29.680: ISDN BR0 Q931: CALL_PROC pd = 8 callref = 0x91
Channel ID i = 0x8A
Dec 20 17:51:29.684: ISDN BR0 Q921: User TX -> RR sapi=0 tei=66 nr=4
Dec 20 17:51:30.008: ISDN BR0 Q921: User RX <- INFO sapi=0 tei=66, ns=4 nr=5
Dec 20 17:51:30.008: ISDN BR0 Q931: CONNECT pd = 8 callref = 0x91
Dec 20 17:51:30.012: ISDN BR0 Q921: User TX -> RR sapi=0 tei=66 nr=5
Dec 20 17:51:30.012: %LINK-3-UPDOWN: Interface BRI0:2, changed state to up
Dec 20 17:51:30.016: %DIALER-6-BIND: Interface BR0:2 bound to profile Di1
Dec 20 17:51:30.016: %ISDN-6-CONNECT: Interface BRI0:2 is now connected to 06........ N/A
Dec 20 17:51:30.020: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=66, ns=5 nr=5
Dec 20 17:51:30.020: ISDN BR0 Q931: CONNECT_ACK pd = 8 callref = 0x11
Dec 20 17:51:30.076: ISDN BR0 Q921: User RX <- RR sapi=0 tei=66 nr=6
Dec 20 17:51:32.076: %ISDN-6-DISCONNECT: Interface BRI0:2 disconnected from 06........ , call lasted 2 seconds
Dec 20 17:51:32.080: ISDN BR0 Q921: User TX -> INFO sapi=0 tei=66, ns=6 nr=5
Dec 20 17:51:32.080: ISDN BR0 Q931: DISCONNECT pd = 8 callref = 0x11
Hall of Fame Super Silver
Re: ISDN problems
Thanks for posting the config and the additional debug output. I think that Georg may be on the right path in suggesting that it might be an authentication problem. Could you run debug ppp negotiation and post that output. (I see little value in having the debug q921 output, given what you have posted so far)
Rick
VIP Purple
Re: ISDN problems
can you try and configure the following on your Dialer1 interface:
interface Dialer1
-->dialer-group 1
And in global config mode add:
dialer-list 1 protocol ip permit
GP
Re: ISDN problems
this is the debug PPP of the router that make the isdn call
Dec 21 15:29:53.655: %ISDN-3-LAYER2_UP: Layer 2 for Interface BR0, TEI 84 changed to up
Dec 21 15:29:54.083: %LINK-3-UPDOWN: Interface BRI0:2, changed state to up
Dec 21 15:29:54.087: %DIALER-6-BIND: Interface BR0:2 bound to profile Di1
Dec 21 15:29:54.087: %ISDN-6-CONNECT: Interface BRI0:2 is now connected to 06........ N/A
Dec 21 15:29:54.099: BR0:2 PPP: Using dialer call direction
Dec 21 15:29:54.099: BR0:2 PPP: Treating connection as a callout
Dec 21 15:29:54.099: BR0:2 PPP: Phase is ESTABLISHING, Active Open
Dec 21 15:29:54.099: BR0:2 PPP: No remote authentication for call-out
Dec 21 15:29:54.099: BR0:2 LCP: O CONFREQ [Closed] id 102 len 10
Dec 21 15:29:54.099: BR0:2 LCP: MagicNumber 0xF7B82B87 (0x0506F7B82B87)
Dec 21 15:29:54.115: BR0:2 LCP: I CONFREQ [REQsent] id 116 len 15
Dec 21 15:29:54.115: BR0:2 LCP: AuthProto CHAP (0x0305C22305)
Dec 21 15:29:54.115: BR0:2 LCP: MagicNumber 0x4DD775DB (0x05064DD775DB)
Dec 21 15:29:54.115: BR0:2 LCP: O CONFACK [REQsent] id 116 len 15
Dec 21 15:29:54.115: BR0:2 LCP: I CONFACK [ACKsent] id 102 len 10
Dec 21 15:29:54.115: BR0:2 LCP: MagicNumber 0xF7B82B87 (0x0506F7B82B87)
Dec 21 15:29:54.115: BR0:2 LCP: State is Open
Dec 21 15:29:54.119: BR0:2 PPP: Phase is AUTHENTICATING, by the peer
Dec 21 15:29:54.131: BR0:2 CHAP: I CHALLENGE id 194 len 27 from "receive"
Dec 21 15:29:54.135: BR0:2 CHAP: Using hostname from unknown source
Dec 21 15:29:54.135: BR0:2 CHAP: Using password from AAA
Dec 21 15:29:54.135: BR0:2 CHAP: O RESPONSE id 194 len 42 from "hostname_router"
Dec 21 15:29:54.151: BR0:2 CHAP: I FAILURE id 194 len 25 msg is "Authentication failed"
Dec 21 15:29:54.155: BR0:2 LCP: I TERMREQ [Open] id 117 len 4
Dec 21 15:29:54.155: BR0:2 LCP: O TERMACK [Open] id 117 len 4
Dec 21 15:29:54.155: BR0:2 PPP: Sending Acct Event[Down] id[6C6C]
Dec 21 15:29:54.155: BR0:2 PPP: Phase is TERMINATING
Dec 21 15:29:56.167: BR0:2 LCP: TIMEout: State TERMsent
Dec 21 15:29:56.167: BR0:2 LCP: State is Closed
Dec 21 15:29:56.167: BR0:2 PPP: Phase is DOWN
Dec 21 15:29:56.167: BR0:2 PPP: Phase is ESTABLISHING, Passive Open
Dec 21 15:29:56.167: BR0:2 LCP: State is Listen
Dec 21 15:29:56.167: BR0:2 LCP: I CONFREQ [Listen] id 118 len 15
Dec 21 15:29:56.167: BR0:2 LCP: AuthProto CHAP (0x0305C22305)
Dec 21 15:29:56.167: BR0:2 LCP: MagicNumber 0x4DD77DE5 (0x05064DD77DE5)
Dec 21 15:29:56.167: BR0:2 PPP: No remote authentication for call-out
Dec 21 15:29:56.171: BR0:2 LCP: O CONFREQ [Listen] id 103 len 10
Dec 21 15:29:56.171: BR0:2 LCP: MagicNumber 0xF7B8339C (0x0506F7B8339C)
Dec 21 15:29:56.171: BR0:2 LCP: O CONFACK [Listen] id 118 len 15
Dec 21 15:29:56.171: BR0:2 LCP: AuthProto CHAP (0x0305C22305)
Dec 21 15:29:56.171: BR0:2 LCP: MagicNumber 0x4DD77DE5 (0x05064DD77DE5)
Dec 21 15:29:56.175: %ISDN-6-DISCONNECT: Interface BRI0:2 disconnected from 06..... , call lasted 2 seconds
Dec 21 15:29:56.263: %LINK-3-UPDOWN: Interface BRI0:2, changed state to down
Dec 21 15:29:56.263: %DIALER-6-UNBIND: Interface BR0:2 unbound from profile Di1
Dec 21 15:29:56.279: BR0:2 PPP: Sending Acct Event[Down] id[6C6D]
Dec 21 15:29:56.279: BR0:2 LCP: State is Closed
Dec 21 15:29:56.279: BR0:2 PPP: Phase is DOWN
Dec 21 15:29:56.731: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
Dec 21 15:29:56.735: %DIALER-6-BIND: Interface BR0:1 bound to profile Di1
Dec 21 15:29:56.739: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 0......... N/A
Dec 21 15:29:56.751: BR0:1 PPP: Using dialer call direction
Dec 21 15:29:56.751: BR0:1 PPP: Treating connection as a callout
Dec 21 15:29:56.751: BR0:1 PPP: Phase is ESTABLISHING, Active Open
Dec 21 15:29:56.751: BR0:1 PPP: No remote authentication for call-out
Dec 21 15:29:56.751: BR0:1 LCP: O CONFREQ [Closed]
VIP Purple
Re: ISDN problems
check the configuration on the other side of the connection, there must be a username matching the name of the calling router (Sendigcall) and a matching password. So basically there must be a line that looks like this:
username Sendigcall password ....
GP
Re: ISDN problems
In the other side there is a username that don't macht the calling router's hostname but is a username created by me.
On the both side there are configurated two idem username with the same password
Example
on the router A (receive call) there are
username send password send
username receive password receive
on the router B (sending call) there are
this is the username configurated in Dialer interface
(if you see the sh run above you can see it there)
VIP Purple
Re: ISDN problems
GP
Re: ISDN problems
YESSSSSSSSSSSSSSSSS it's as you say!!!!!!!!!!!!!!!!
THANK YOU A LOT!!!!!!!!!!
Your information are been very helpful!!!!!!!
Thank you thank you thank you!!!!!
Re: ISDN problems
How if there is no authentication in my configurations? I got exactly the same messages.
Nelson
Re: ISDN problems
Nelson
We would be able to help you better if you would post the router configs and perhaps some of the messages that you are getting.
Rick
Re: ISDN problems
Here is the configration and the error messages, is this enough for your reference?
version 12.3
service timestamps log datetime localtime
hostname Router
boot-start-marker
boot-end-marker
logging buffered 8192 debugging
logging monitor informational
enable secret 5
clock timezone GMT+8 8
no network-clock-participate aim 0
no network-clock-participate aim 1
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
interface FastEthernet0/0
description "ISDN Router intranet"
ip address
ip access-group 113 in
no ip redirects
no ip unreachables
no ip mroute-cache
duplex auto
speed auto
standby 1 ip
standby 1 priority 90
standby 1 authentication
interface FastEthernet0/1
ip address
ip access-group 111 in
no ip redirects
no ip unreachables
no ip mroute-cache
duplex auto
speed auto
standby 2
standby 2 priority 90
standby 2 authentication
interface BRI1/0
ip address
encapsulation ppp
dialer idle-timeout 30 either
dialer map
dialer-group 1
interface BRI1/1
ip address
encapsulation ppp
shutdown
dialer map ip x.x.x.x yyyyy
dialer-group 1
interface BRI1/2
ip address
encapsulation ppp
dialer map ip
dialer-group 1
interface BRI1/3
no ip address
interface BRI1/4
no ip address
interface BRI1/5
no ip address
interface BRI1/6
description *** to YD ***
ip address
ip accounting output-packets
encapsulation ppp
dialer map ip
dialer-group 1
interface BRI1/7
no ip address
router eigrp 100
redistribute static
passive-interface FastEthernet0/1
passive-interface BRI1/0
passive-interface BRI1/1
passive-interface BRI1/2
passive-interface BRI1/3
passive-interface BRI1/4
passive-interface BRI1/5
passive-interface BRI1/6
passive-interface BRI1/7
no auto-summary
ip classless
ip route
no ip http server
ip http authentication local
ip http timeout-policy idle 600 life 86400 requests 10000
logging trap debugging
access-list 1 permit
access-list 2 permit
access-list 110 deny
access-list 110 permit
access-list 111 deny
access-list 111 permit
access-list 112 permit
access-list 113 permit ip any any
dialer-list 1 protocol ip list 111
dialer-list 2 protocol ip permit
snmp-server community RO
snmp-server enable traps tty
control-plane
line con 0
login local
line aux 0
line vty 0 4
scheduler allocate 20000 1000
end
3085: *Mar 10 08:24:16: Layer 2 for Interface BR1/2, TEI 86 changed to down
3084: *Mar 10 08:23:35: Layer 2 for Interface BR1/2, TEI 86 changed to up
Re: ISDN problems
Nelson
This is a good starting point. The config that you posted does not have any authentication. Can you also post the config from the device that you are attempting to communicate with?
Authentication is not the only thing that can produce these symptoms. So it might be helpful to run debug isdn q921 and debug isdn q931 and post the output of the debugs.
Rick
Re: ISDN problems
Hi Rick,
Here is the output of those two commands,
03:30 PM 3175: *Mar 22 07:29:28.846: ISDN BR1/2 Q931: L3_ShutDown: Shutting down ISDN Layer 3
03:30 PM 3174: *Mar 22 07:29:28.190: ISDN BR1/2 Q921: User TX -> IDREQ ri=17890 ai=127
03:30 PM 3173: *Mar 22 07:29:18.882: ISDN BR1/6 Q931: L3_ShutDown: Shutting down ISDN Layer 3
03:30 PM 3172: *Mar 22 07:29:18.234: ISDN BR1/6 Q921: User TX -> IDREQ ri=47313 ai=127
03:30 PM 3171: *Mar 22 07:29:08.918: ISDN BR1/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
03:30 PM 3170: *Mar 22 07:29:08.306: ISDN BR1/0 Q921: User RX <- IDDENY ri=64464 ai=127
03:30 PM 3169: *Mar 22 07:29:08.262: ISDN BR1/0 Q921: User TX -> IDREQ ri=64464 ai=127
02:28 PM 3168: *Mar 22 06:26:58.502: ISDN BR1/2 Q931: L3_ShutDown: Shutting down ISDN Layer 3
02:28 PM 3167: *Mar 22 06:26:57.854: ISDN BR1/2 Q921: User TX -> IDREQ ri=7647 ai=127
02:27 PM 3166: *Mar 22 06:26:48.438: ISDN BR1/6 Q931: L3_ShutDown: Shutting down ISDN Layer 3
02:27 PM 3165: *Mar 22 06:26:47.786: ISDN BR1/6 Q921: User TX -> IDREQ ri=15870 ai=127
02:27 PM 3164: *Mar 22 06:26:38.442: ISDN BR1/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
02:27 PM 3163: *Mar 22 06:26:37.794: ISDN BR1/0 Q921: User TX -> IDREQ ri=35629 ai=127
01:25 PM 3162: *Mar 22 05:24:28.082: ISDN BR1/2 Q931: L3_ShutDown: Shutting down ISDN Layer 3
01:25 PM 3161: *Mar 22 05:24:27.430: ISDN BR1/2 Q921: User TX -> IDREQ ri=17516 ai=127
01:25 PM 3160: *Mar 22 05:24:18.102: ISDN BR1/6 Q931: L3_ShutDown: Shutting down ISDN Layer 3
01:25 PM 3159: *Mar 22 05:24:17.454: ISDN BR1/6 Q921: User TX -> IDREQ ri=47291 ai=127
01:25 PM 3158: *Mar 22 05:24:08.054: ISDN BR1/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
01:25 PM 3157: *Mar 22 05:24:07.406: ISDN BR1/0 Q921: User TX -> IDREQ ri=18202 ai=127
12:23 PM 3155: *Mar 22 04:21:57.007: ISDN BR1/2 Q921: User TX -> IDREQ ri=24201 ai=127
12:23 PM 3156: *Mar 22 04:21:57.655: ISDN BR1/2 Q931: L3_ShutDown: Shutting down ISDN Layer 3
12:22 PM 3153: *Mar 22 04:21:47.031: ISDN BR1/6 Q921: User TX -> IDREQ ri=32264 ai=127
12:22 PM 3154: *Mar 22 04:21:47.679: ISDN BR1/6 Q931: L3_ShutDown: Shutting down ISDN Layer 3
12:22 PM 3152: *Mar 22 04:21:37.667: ISDN BR1/0 Q931: L3_ShutDown: Shutting down ISDN Layer 3
12:22 PM 3151: *Mar 22 04:21:37.019: ISDN BR1/0 Q921: User TX -> IDREQ ri=13463 ai=127
Many thanks for your support!
Nelson
Re: ISDN problems
Nelson
It looks to me from this debug that there is a problem in your router trying to talk to the ISDN switch. It might be helpful if you would post the output of show isdn status. I think that you might also ask your provider what, if anything, they are seeing from you and to review the configuration parameters in your router to their version of what the parameters should be.
Rick
Re: ISDN problems
Rick,
This is the output of show isdn status.
ISDN BRI1/0 interface
dsl 8, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 8 CCBs = 0
The Free Channel Mask: 0x80000003
ISDN BRI1/1 interface
dsl 9, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Active dsl 9 CCBs = 0
The Free Channel Mask: 0x00000000
ISDN BRI1/2 interface
dsl 10, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Active dsl 10 CCBs = 0
ISDN BRI1/3 interface
dsl 11, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Active dsl 11 CCBs = 0
ISDN BRI1/4 interface
dsl 12, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Active dsl 12 CCBs = 0
ISDN BRI1/5 interface
dsl 13, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Active dsl 13 CCBs = 0
ISDN BRI1/6 interface
dsl 14, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Active dsl 14 CCBs = 0
ISDN BRI1/7 interface
dsl 15, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Active dsl 15 CCBs = 0
Total Allocated ISDN CCBs = 0
Thanks for your help!
Nelson
Re: ISDN problems
Nelson
These lines:
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
which appear on each of your BRI interfaces indicate that there is no connectivity between your router and the ISDN switch. You need to get that resolved. I can not tell whether it is a physical connectivity problem or a configuration mismatch between your router and the switch. But your router and the ISDN switch are not talking and that is your immediate problem.
Rick
Re: ISDN problems
Pls grab some of the sample configs at http://ciscorouterconfig.blogspot.com/
583
