ISDN Redundant Connectivity
Hardware: Two Cisco 2821 Routers with Bri interface
Connectivity: ISDN dedicated/DOD link for Both routers
Q: How we can provide link redundancy by using ISDN connection. Also I need router redundancy too.
I need to use static routing only
Only one ISDN link per router no other links
Please suggest me a solution for this with needed configurations
Thanks & Regards
Satheerthan S
Re: ISDN Redundant Connectivity
Satheerthan
If i were you, i would use ISDN dialer watch and dynamic routing.
However, if you insist to only use static routes. You may able to get away with HSRP and HSRP interface tracking on your WAN interface.
- In event of R1 WAN link was down, R2 become active and route your traffic via ISDN connections.
- In event of R1 WAN link was down and R2 also was down, R1 remain active and route your traffic via local ISDN connections.
there are many other solutions for your requirement. however, i think dialer watch is the best for your senario.
regards,
Eng Siong
Dear Eng Siong,
Thanks for your solution,
I have some doubts in this.
How we can configure HSRP in WAN interface?.
Can we use HSRP with dialer watch?
What are the other solutions for this specific requirement.(Router redundancy and link redundancy, Only 2 BRI ISDN connections)
Can you please suggest with sample configuration.
Satheerthan
Yon only need to configure HSRP for your LAN interface. You can setup your R1 WAN router as primary hsrp router. As well as that, configure the R1 HSRP to track your WAN interface.
If R1 WAN interface was down, it would reduce the HSRP priority, so the R2 backup isdn router can take over as default gateway and route traffic via ISDN connection.
If R1 WAN interface and R2 router were down at the sametime. R1 remain as default gateway router and route traffic via ISDN connection using floting static route.
hope this helps....
sample config.
ISDN-R1
interface FastEthernet0/0
description - PRIMARY LAN INTERFACE -
ip address 10.10.10.2 255.255.255.0
speed 100
full-duplex
standby 10 ip 10.10.10.1
standby 10 priority 150
standby 10 preempt
standby 10 track Serial1/0.103 80
interface Serial1/0
no ip address
encapsulation frame-relay
serial restart-delay 0
no frame-relay inverse-arp
interface Serial1/0.103 point-to-point
description - FR WAN Connection -
ip address 20.x.x.1 255.255.255.0
frame-relay interface-dlci 103
interface bri 0
encapsulation PPP
dialer pool-member 1
interface dialer0
ip 30.x.x.1 255.255.255.0
encapsulation ppp
dialer remote-name Remote-Router
dialer pool 1
dialer string 5551212
dialer-group 1
ip route 0.0.0.0 0.0.0.0 Serial1/0.103
ip route 0.0.0.0 0.0.0.0 dialer0 100
ISDN-R2
description - SECONDARY LAN INTERFACE -
ip address 10.10.10.3 255.255.255.0
speed 100
full-duplex
standby 10 preempt
interface bri 0
encapsulation PPP
interface dialer0
ip 40.x.x.1 255.255.255.0
encapsulation ppp
dialer pool 1
dialer-group 1
regards,
eng siong
Eng Siong,
Thanks for your help.
I will try to implement this and getback to you..
Thanks & Regards
Satheerthan
129
