ISDN used timer
AmandMimoza
i have configured un ISDN backup connections to un CDN.
I have not traffics DDR because the CDN connections is UP, but when i do:
show isdn status
the output is
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
In ---N/A--- ---N/A--- +1-extranet +57362
the parameter second used is incrementing.
I try different debuge but i have not output.
Any body can help mi to understand why ?
Best regards
5 Replies 5
spremkumar
Level 9
Level 9
Hi Amand
Can you check up the config which mite be allowing any kinda traffic to trigger the isdn and keep it on.
regds
smothuku
Level 7
Level 7
Hi ,
can you paste the config ? Have you configured the ISDN backup commands on primary interface.
You are getting incoming call from extranet+57362.Better check the config at remote end also.
Satish
Here is the configuration on both site, remote and central site.
The name +1-extranet is the a part of the name?s router central site and the number that in incrementing +80176 are the seconds busy connections.
Central site
interface Serial4/0
description Link vs
bandwidth 2048
ip address x.x.x.x y.y.y.y
backup interface Dialer5
no ip mroute-cache
load-interval 30
serial restart_delay 0
end
interface Dialer5
description Dialer group controlling the BRI1/4-BRI1/7
encapsulation ppp
dialer pool 5
dialer remote-name bbbbbbb
dialer idle-timeout 900
dialer string 0257515249
dialer string 0289263551
dialer string 0257516908
dialer string 0257516910
dialer load-threshold 1 either
dialer max-call 8
dialer-group 5
no cdp enable
ppp authentication chap
ppp multilink
end
interface BRI1/4
description ISDN number
no ip address
encapsulation ppp
dialer pool-member 5
isdn switch-type basic-net3
isdn point-to-point-setup
no cdp enable
ppp multilink
end
Remote site
interface Serial0/0
description link verso
bandwidth 2048
backup interface Dialer1
no ip mroute-cache
interface Dialer1
description Dialer group controlling the BRI1/0-BRI1/3
ip address 10.56.143.158 255.255.255.252
encapsulation ppp
dialer pool 1
dialer remote-name RRRRRRRRRR
dialer string 0248376621
dialer string 0248376036
dialer string 024125322
dialer string 024125261
dialer max-call 8
dialer-group 1
no cdp enable
ppp multilink
end
interface BRI1/0
no ip address
encapsulation ppp
dialer pool-member 1
no cdp enable
ppp multilink
end
Mimoza
why are u configure dialer string in both end. i hope remote end will be dialing to Central site when primarry link is going down.
pl.clearfy this
sap.
Hi Mimoza ,
Are you dialing from remote site to central site or from central site to remote site ?
satish
