ISDN
Dear All,
isdn is backup at remote end
if leased line goes down.isdn want to fire automaticaly.so waht is the command for fire the ISDN automtocaly
Silver
Re: ISDN
Hi Sasi ,
At the remote end you need to configure below commands under serial so that ISDN will be fired in case of leased line goes down.
Int s0
backup delay 5 120
backup interface bri0
Satish
Re: ISDN
Dear sathish,
backup delay 5 means if leasedline goes down after 5min ISDN will Work..
Re: ISDN
HI SaiKumar, [Pls RATE if HELPS]
Refer Link below for a Cisco Document explaning on how to configure the Dialer Backup for the Serial Line.
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_configuration_example09186a0080094cb0.shtml#diag
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
108
