08-10-2006 08:57 AM - edited 03-03-2019 01:36 PM
Hello there, I will like to know if some of you can share a Best practice using 3 different platforms (Alcatel, Nortel and Siemens) over a Cisco ISIS Network. Right now we are using that scenario, but we are having a lot of issues trying to add more elements (nodes) to the ISIS Network ...
- The Network has all three NETs over a single area, here's an example
router isis Alcatel-Nortel
net 47.0005.8000.0000.0000.0001.0001.0050.534a.aaff.00
net 49.0001.0050.534a.aaff.00
is-type level-1
log-adjacency-changes
router isis Siemens
net 47.0099.0548.4000.0100.0000.0100.0050.534a.aaff.00
is-type level-1
And I have these is applied to two LANs
Any help, will be a lot appreciated
08-17-2006 07:50 AM
There is no seperate configuration for different platforms.Make sure Area ID and IS-type matches.Refer the following URL for configuring IS-IS http://www.cisco.com/warp/public/97/is-is-ip-config.html.
08-17-2006 08:10 AM
I am not sure about your statement "single area". To my knowledge ISIS area is the same on two devices, when the network portion of the NSAP (NET) address is the same.
If different NET addresses need to be connected then a Level2 router is needed.
So can you try to remove "is-type level-1" from your config? The router will then be Level1 as well as Level2 router and should be able to route between different areas.
Also, why do you have two ISIS processes started?
You could try to use the following config to interconnect all areas:
clns routing
router isis all
interface FastEthernet0/0
clns router isis all
You need to adjust this to your interfaces.
Hope this helps! Please rate all posts.
Regards, Martin
