ISIS - not forming neighbor
Any ideas on why these two devices are not communicating via ISIS? Ping tests run fine. All I see from the CMTS is that it is sending hellos, but not receiving.
CORE ROUTER
interface GigabitEthernet3/0.250
encapsulation dot1Q 250
ip address 172.18.X.X 255.255.255.240
no ip directed-broadcast
ip router isis 49
clns mtu 1460
router isis 49
net 49.0450.1720.3103.5001.00
is-type level-1
area-password TEST
metric-style wide
no hello padding
redistribute static ip route-map Static-ISIS level-1
passive-interface GigabitEthernet3/0.11
passive-interface Loopback0
mtu 1526
CMTS
interface FastEthernet0/0
no ip redirects
ip router isis 49
no ip mroute-cache
duplex full
no cdp enable
clns mtu 1460
router isis 49
net 49.0450.1720.3103.5011.00
is-type level-1
area-password TEST
metric-style wide
no hello padding
Re: ISIS - not forming neighbor
I would suggest you run a "deb isis adj" on the core router to find out if the hellos are sent correctly.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
This is all the info I have to go with for now due to access issues. Thanks for the input though, if I end up getting access, I will do so.
just a thought: remove the area password, to be sure not to run into issues like spaces at the end in one config ...
Also one question: why is the CLNS mtu set to 1460? is there anything inbetween potentially causing large packets to be dropped?
Regards, Martin
CLNS neighbors must have the same MTU.
Check this link (MTU Mismatch Problem in IS-IS)
http://www.cisco.com/en/US/customer/tech/tk365/technologies_tech_note09186a00801e1e2b.shtml
Best Regards,
George
1624
